Jdm B18c swap query.
Old Jan 11, 2007 | 02:45 PM
NZDelsoldude's Avatar
Default Jdm B18c swap query.
I'm just finishing off my obd2 jdm b18c swap. but don't know what the last plug is for.
And what does the vacuum fitting on the manifold go to?
Old Jan 11, 2007 | 02:47 PM
Amped's Avatar
Default Re: Jdm B18c swap query. (NZDelsoldude)
its hard to see what that plug is coming from? I dont see a vacump port on the intake either.
Old Jan 11, 2007 | 02:48 PM
VRD^sam's Avatar
what color are those wires?
Old Jan 11, 2007 | 03:23 PM
Luserkid's Avatar
Default Re: Jdm B18c swap query. (get^bent)
That plug looks like an 02 sensor plug.
No vac. line that i see either.
Old Jan 11, 2007 | 03:25 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NZDelsoldude &raquo;</TD></TR><TR><TD CLASS="quote">I'm just finishing off my obd2 jdm b18c swap. but don't know what the last plug is for.
What's the colors and how many wires?
Not seeing anything. Please be more specific.
Old Jan 11, 2007 | 03:27 PM
B18CivicEH2's Avatar
Default Re: Jdm B18c swap query. (poison)
vacuum lines should look like this
Old Jan 11, 2007 | 04:44 PM
I've circled it now.
And the connector has four wires coming off the engine loom. They are white, black/white, yellow/black, and green/black.
Old Jan 11, 2007 | 05:17 PM
APCforthewin's Avatar
that plug is your 02 sensor plug.
1 (green) goes to D13 (green/ blk) for sensor ground
2 (white) goes to D14 (white/ red) for sensor signal
3 (blk/white) goes to A5 (blk/ white) for heater signal
4 (blk/yellow) needs to "TAP" into A11 (yellow/ blk) for 12v power
Almost positive that vacuum fitting is for the evap purge diaphram valve. you can see in the pic.
Old Jan 11, 2007 | 06:00 PM
Default Re: Jdm B18c swap query. (APCforthewin)
cheers. So should I just block off the vacuum fitting as my charcoal canister doesn't have a evap diaphram purge valve. It only has two connections, one from the gas tank and the other to the TB.
Old Jan 11, 2007 | 07:03 PM
Also becuase i'm using the obd1 ecu and the 0bd2 loom and engine, am I still able to use my single wire o2 sensor? If so how do I wire it?
Old Jan 11, 2007 | 07:26 PM
StreetRacinThug's Avatar
I need some information before I can help.
What vehicle? (Year, model, trim)
What harness? (EX,Si or DX, LX, CX)
OBD2a or OBD2b
First off the car is OBD1 you need to start by taking off the OBD2 harness. And get yourself a EX or Si harness from the Coupe or Hatch.
If the car is OBD2 and your using a OBD1 ECU are you sure you have a Conversion Harness.
If the car, motor, harness are all OBD2A then it should be plug and play for your O2 sensors. And im assuming if using the correct harness that came with the car and the single cam you have to extend the 02 sensor wires from the front to the back since the Single Cam header has the bong near the Slave Cylinder and the B Series header has it under the intake manifold past the oil pan.
So yeah theres diffrent possibities.
P.S Why is there a heater hose/coolant hose disconnected by the Thermostat.
Old Jan 11, 2007 | 09:07 PM
Default Re: (StreetRacinThug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug &raquo;</TD></TR><TR><TD CLASS="quote">I need some information before I can help.
OBD2a or OBD2b
P.S Why is there a heater hose/coolant hose disconnected by the Thermostat.</TD></TR></TABLE>
I haven't put that hose on yet, that's all.
My car is a 92 delsol and the engine is 1996 b18c. I'm using the obd2 wiring harness so that I don't have to change the connections to the alternator, injectors etc.....
Old Jan 11, 2007 | 10:23 PM
First of all, you HAVE TO get a harness that matches your cars spec. First of all I believe Del Sols were only made in 94-96 but that might be just the B16 ones. Correct me if im working. At this point if I were you I would just by a Del Sol Si harness OBD1 so I can match with my car. Just simply cut the injector clips off. Cut the wires and then cut the ones on the harness. Color match them twist real nice. Solder them if you can. Tape them up REALLY NICE just roling the roll of ELECTRICAL tape over it nice and tight. Exactly like installing a stereo. Its so easy. Same with Alternator. Then your car will work when you got to start it!
Whats up with people trying to use OBD2 stuff in OBD1 or vice versa. I think you might be looking into a OBD1 Dizzy
Old Jan 11, 2007 | 11:06 PM
Ok thanks. I still have the original obd1 sohc harness I can use. I just remember reading somewhere that I could use the obd2 harness. Also what is the deal with the secondary oxygen sensor, if I remove it will I throw a code? How do I get Round this as my custom exhaust will have no cat.
Old Jan 12, 2007 | 03:46 AM
Default Re: (NZDelsoldude)
Have you tried searching on this my man? im sure you can find a few decent right ups.
Old Jan 13, 2007 | 02:14 PM
Forget searching. You wont throw a CEL because OBD1 only has one O2 not 2 like OBD2. So yes
you can run striaght pipe without the check engine light.
Old Jan 15, 2007 | 04:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug &raquo;</TD></TR><TR><TD CLASS="quote">Forget searching. You wont throw a CEL because OBD1 only has one O2 not 2 like OBD2. So yes
you can run striaght pipe without the check engine light.</TD></TR></TABLE>
My del sol has two standard and it's obd1...........
gennc
Engine Management and Tuning
Sep 22, 2014 02:26 PM
spaazm
Apr 11, 2012 09:31 PM
Jeff 360
Feb 16, 2012 05:13 PM
Nameless RB26
Oct 13, 2002 10:56 PM
