polish rods?
Old May 14, 2002 | 09:18 PM
Quetzolcotl's Avatar
Default polish rods?
i read on integra.vtec.net that polishing stock rods gives them added strengh. is this true? so could i then polish them with a dremel tool or is it more complicated than that?
Old May 14, 2002 | 10:34 PM
Lsos's Avatar
Default Re: polish rods? (Quetzolcotl)
Polishing could remove stress risers, but I don't know how much of a difference it would make on a rod....
Old May 14, 2002 | 11:25 PM
Rocket's Avatar
Default Re: polish rods? (Lsos)
I wouldn't was time on polishing the rods unless the rules of the race your running says you have to run stockers and you want that exxtra bit of insurance.
Polishing does nothing more than decrease the chance of a crack starting. If you get serious detonation, you'll just wind up with a bent or broken rod that is polished.
Same goes for shot peening. Sheet peening leaves a compressed surface layer that resist cracks. I've seen many shot-peened rods bent like Gumby after heavy detonation.
Old May 15, 2002 | 03:18 AM
BROOD's Avatar
This polishing is called "beaming" connecting rods. Like Rocket said before me, it is done to remove possible stress risers that can be found in the parting line of the rod. The parting line is blended into the main body of the con rod and then shotpeened afterwards. If you can remove any possible stress risers, then cracks won't propagate as easily under heavy usage.
Beaming is more of a mechanical means to strengthen con rods, like shootpeening. Cryo and vibration treatments increase strength a little differently than that.
*keep in mind that simply grinding off the parting line is not a good idea, it has to be blended into the rod instead*
[Modified by SLPR, 4:21 AM 5/15/2002]
Old May 22, 2002 | 07:45 AM
rota426's Avatar
Default Re: polish rods? (SLPR)
Qoute: "If you get serious detonation, you'll just wind up with a bent or broken rod that is polished."
--haha, true-dat
Old May 22, 2002 | 09:51 AM
Rocket's Avatar
Default Re: polish rods? (styler7)
True that and sad.
K2e2vin
Jun 12, 2006 01:10 PM
Retired
Dec 14, 2005 09:00 AM
johncarlos
May 1, 2004 02:51 AM
asubennett
Mar 1, 2004 11:16 PM
