Trouble is rear lower tie bar
did that one side lines up the other wont
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">use a jack.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwf1988 »</TD></TR><TR><TD CLASS="quote">did that one side lines up the other wont
Use a mallet, then. I can't think of any reason those two shouldn't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaddict14 »</TD></TR><TR><TD CLASS="quote">grab the good old bfh</TD></TR></TABLE>
I love my BFH.
I love my BFH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwf1988 »</TD></TR><TR><TD CLASS="quote">i used a hammer and a screw driver through the bolt whole and no luck</TD></TR></TABLE>
Is your LCA horseshoed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwf1988 »</TD></TR><TR><TD CLASS="quote">what u mean ,, sorry man</TD></TR></TABLE>
Bent.
Bent.
push the LCA up and down while you are under the car and have someone pulling the wheel back and foward from the outside untill it lines up...
weird you getting this prob, when i threw mine on, took me like 5 mins...didnt have probs with the LCA...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEg »</TD></TR><TR><TD CLASS="quote">push the LCA up and down while you are under the car and have someone pulling the wheel back and foward from the outside untill it lines up...
weird you getting this prob, when i threw mine on, took me like 5 mins...didnt have probs with the LCA...</TD></TR></TABLE>
ya i know,, i talked to some people and looked at it, they said the lca is normal just hard to put the bold back in place, one of those odd situations. What would cause a bent lca i might ask
ya i know,, i talked to some people and looked at it, they said the lca is normal just hard to put the bold back in place, one of those odd situations. What would cause a bent lca i might ask</TD></TR></TABLE>
i would guess by hitting like a curb or something..
I typically grab the control arm with a big assed pair of pliers (Channel locks) and twist the whole arm to get the bushings to line up. While the arms attached to the trailing arm, the trailing arm applies a "twist" to the arm. That's why you can't get the bushing holes to line up. That's why the screwdriver doesn't work either, you might get the bushing straight for a second then when you pull the driver back out it twists in place again.
From the back of the car, I grab the bottom edge of the arm and twist upwards with the channel locks. That shifts the front end of the bushing down to line up the hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwf1988 »</TD></TR><TR><TD CLASS="quote">no its not bent. why do i need it alighnment after that</TD></TR></TABLE>
some need an alignment to prevent premature tire wear because their tires aren't straight after they work on the suspension.
This guy has the same idea with more detail. follow his instructions and you should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwf1988 »</TD></TR><TR><TD CLASS="quote">i mean im not trying to be a ***, i just dont understand how it will effect the alghiment. i messed with the wheel alot too</TD></TR></TABLE>
i dont think you should worry about it..
