Help: My AC broke can anyone help?
Old May 14, 2002 | 08:50 PM
inochi's Avatar
New User
Default Help: My AC broke can anyone help?
My aircondtioning is not functioning. I have a 96 Accord. I have noticed a few problems.
First:
When I turn the **** after about 6/8th of the way it starts to make a snapping noise. This is for the heat/cold ****.
Second:
The Heat and cold dont work. I think its a result of the **** or the **** is a result of this.
Third :
When I turn on the a/c and the engine is off I hear a scratching noise in the front of the car. We looked at it an its the air fans in the front that are making the nose.
If anyone knows how to fix this....I will be very grateful. Please someone help. Thanks in advance.
Keith
Old May 14, 2002 | 08:55 PM
Gennady's Avatar
New User
Default Re: Help: My AC broke can anyone help? (inochi)
Its your **** thats broken, not your AC.
Why would you do this?
Old May 14, 2002 | 10:41 PM
KTeller8's Avatar
Default Re: Help: My AC broke can anyone help? (Wont be beat)
yeah it sounds like what happen to mine..
i pulled off the **** and the little square thingy on the inside was broke.. which meant when i turned the ****.. i got some noise and it didnt pull the cable to let it know i was doing anythign.. kinda like being stripped
Old May 15, 2002 | 05:30 AM
CmptchAV6's Avatar
Third :
this should be your easiest one to fix. All you have to do is figure out where the fan is having clearnance issues and resolve that.
Old May 15, 2002 | 05:31 AM
CmptchAV6's Avatar
I do this all the time when I go to the track to cool off my engine between runs. It is a good way to get cooler air blowing on the engine.
Old May 15, 2002 | 05:37 AM
Gennady's Avatar
New User
Default Re: Help: My AC broke can anyone help? (CmptchAV6)
Dont you turn on the heat when you cool your engine? The AC only heats things up.
Old May 15, 2002 | 05:40 AM
CmptchAV6's Avatar
I turn off the engine turn on the heat and then turn on the AC. Since the AC automatically turns on both fans on my radiator it is a great way to cool down the engine. The interior of the car gets hot real quick tho
Old May 15, 2002 | 05:41 AM
Gennady's Avatar
New User
Ok, I see. Since the engine is off, there is not additional engine heat created.
Old May 15, 2002 | 05:53 AM
CmptchAV6's Avatar
Precisly
Old May 16, 2002 | 03:50 PM
inochi's Avatar
New User
Well I didnt do it intentionally. I just did it and heard that noise. So I tried it again and relized it was the fans infront of the engine
[Modified by inochi, 4:50 PM 5/16/2002]
Old May 16, 2002 | 03:52 PM
inochi's Avatar
New User
so all I have to do is replace my ****? And that should fix all my problems? Someone suggested that I recharge my freon? Can that be possible too?
Old May 16, 2002 | 07:44 PM
BreakStuff's Avatar
New User
just replace the ****.. a quick diagnosis...switch the temp mode **** with fan speed ****..
If the condensor fan is hitting the shroud, this can be duplicated by accelerating the car quickly with the a/c on.. the noise is quite significant.. if the fan blades are hitting the shround then it is due to a bent front motor on the 94-97 series Accords.. these mounts will bend easily with the slightest "fender bender"...
Old May 17, 2002 | 12:48 PM
The_In_Kid's Avatar
why don't you just pop the hood to cool the engine?
Old May 17, 2002 | 01:01 PM
4doorH22's Avatar
Default Re: Help: My AC broke can anyone help? (The_In_Kid)
Pop hood, HVAC blower, radiator fans, everything you can. Can't overcool a hot engine (well you don't wanna pour ice water on it).
Actually after a hard run, it's best to leave your motor running for a minute or two with the hood open and blower and heat on... this keeps the coolant flowing and gets the hotest coolant out of the motor and the cooler coolant out of the radiator and into the motor where it belongs.
Old May 17, 2002 | 05:04 PM
CmptchAV6's Avatar
Default Re: Help: My AC broke can anyone help? (4doorH22)
yeah it takes me a minute or 2 to look at my times and get all the setting ready for the cool down process. Also I let the car cool for 5 minutes at a time then start it up for 30 seconds and then turn it back off and run the fans again. This helps circulate the hot coolant.
Old May 18, 2002 | 06:12 AM
inochi's Avatar
New User
Default Re: Help: My AC broke can anyone help? (BreakStuff)
thanks guys...ill try it out to see if it works. I appreciate all this.
Old May 18, 2002 | 08:00 PM
inochi's Avatar
New User
replacing the ***** did not work. Any other suggestions? I think its the actual lever that the **** pulls. How do i fix that?
Old May 19, 2002 | 07:01 PM
inochi's Avatar
New User
ttt
Masonray19
Honda Civic (2006 - 2015)
Jun 17, 2013 01:49 PM
aznwash3wboi
Mar 7, 2007 05:04 PM
fujiwara takumi
Jul 15, 2006 10:51 AM
rentalman76
May 5, 2003 09:07 AM
Hans
Dec 21, 2002 09:16 PM
