Clunking sound from rear.
Old May 14, 2002 | 08:37 PM
KF_S2000's Avatar
Default Clunking sound from rear.
Does anyone else get a "clunking" (for lack of a better term) sound from the rear of their R when going over some bumps (usually the meaner ones) and rougher roads? My suspension mods are KONI yellow dampers with Eibach Pro Kit springs. The suspension that was on there before were Neuspeed Race springs with stock Type R shocks (the guy before me put that suspension on). I've never experienced an R with stock suspension so I don't know if this is a normal sound to be getting. Thanks for any input.
[Modified by kf_Type-R, 8:17 AM 5/15/2002]
Old May 15, 2002 | 09:15 PM
racecarpete's Avatar
Default Re: Clunking sound from rear. (kf_Type-R)
wasup i actually get this on my civic and i had it with stock suspension. i wish i knew what it was.
Old May 15, 2002 | 10:24 PM
TypeR_853's Avatar
haven't had that problem...i know that isn't normal for a stock suspension though. how new are your konis? i heard they have shorter life than some other companies...but they are good. bushings?
Old May 15, 2002 | 11:10 PM
Gump's Avatar
Default Re: Clunking sound from rear. (TypeR_853)
mine used to do that, it ended up being the swaybar tapping against my axleback exhaust
Old May 15, 2002 | 11:37 PM
MattGSR's Avatar
Default Re: Clunking sound from rear. (Gump)
i hear that too from time to time, coming from my right rear suspension during humps and bumpy roads hmmmm anybody have any ideas. still have stock shocks/springs but progress swaybar
Old May 16, 2002 | 07:48 AM
Default Re: Clunking sound from rear. (MattGSR)
alright well i was checking out the silent recalls and it turns out that there was one that said clunking from rear supspension so i checked it out and they said the bushing in the rear right trailing arm are defective. For civics honda will replace this free. Don't know bout you guys but that is some food for thought. me personally i am gonna go with the prothane urethane bushings as opposed to the stock honda ones. later
Old May 16, 2002 | 08:04 AM
KF_S2000's Avatar
Hmm, I've never heard that about the Konis. The ones I have in their now have been in for less than 5000 miles. The R just turned over 27,000 miles. When I installed the suspension, I inspected the bushings and they "looked" okay, but visual inspection isn't always accurate. Well, I'll just live with it until I notice it becoming a problem. Thanks for the replies everyone.
Old May 16, 2002 | 09:03 AM
Chris's Avatar
MAKE SURE THE ENDLINK BUSHINGS ARE STILL GOOD!
Especailly if you only hear the clunk when going over a bump sideways (one rear wheel at a time)
Old May 16, 2002 | 09:10 AM
TypeR_853's Avatar
bushings is probably your best bet...yeah i heard they're really good, but go soft sooner than others -- although it could be totally dependent on how you drive .. g'luck man!
jdm95
Suspension & Brakes
Jan 10, 2010 11:30 PM
Shorthand
Suspension & Brakes
11
Oct 8, 2007 04:03 PM
wuggiewuggie
Suspension & Brakes
Feb 22, 2007 11:50 AM
slimbo
Sep 30, 2002 11:18 PM
