Which cams are best for all motor daily driven ?
I pretty much just want to know which camshafts are best for all motor and daily driven use also, but will still give you good power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BackYardTuning(818) »</TD></TR><TR><TD CLASS="quote">I pretty much just want to know which camshafts are best for all motor and daily driven use also, but will still give you good power. </TD></TR></TABLE>
Whats your setup?
Whats your setup?
Stage3 minimum. Never had a problem running them in daily driven applications.
ImportPowerHouse/RS Machine has a real good stage3 cam we use all the time.
My setup is a stock B18C5 but i bent the valves and I'm gonna redo the head with all new valvetrain. Just don't know which to go with for DD and good power.
Thank you for a little information. If you bumped the compression ratio a bit i would suggest the rocket motorsports lineup. This is where cleanrice takes over
Any others. Need help!!!
