identify this part plz!!!
Old Jan 10, 2007 | 11:29 PM
slayerfromhell212's Avatar
Default identify this part plz!!!
i was wondering what this part is called and is there a way to fix it cuz its lose
http://i70.photobucket.com/alb...D.jpg
Ritchie's Avatar
Default Re: identify this part plz!!! (slayerfromhell212)
don't see the image.
Old Jan 10, 2007 | 11:36 PM
Default Re: identify this part plz!!! (EGnewbie)
can you see it now and if you dont show me how to put pics up on thread plz
Old Jan 10, 2007 | 11:37 PM
Timmay's Avatar
shift linkatge and it will be loose... im sure its fine
Old Jan 10, 2007 | 11:38 PM
Default Re: identify this part plz!!! (Timmay)
nah its not that one the shift linkages i put energy suspension bushings the 1 that goes into the tranny when you change gears
Old Jan 10, 2007 | 11:40 PM
TwoKSiR's Avatar
What do you mean by loose? It should move like a hinge. It there is other play in it the describe it.
Old Jan 10, 2007 | 11:43 PM
dustinO's Avatar
wtf are you trying to point at?
shift linkage? bitch pin? rubber boot?
christ
Old Jan 10, 2007 | 11:44 PM
Default Re: identify this part plz!!! (TwoKSiR)
well like when im in gear your able to move it left and right a little not too much
i have a d16b7 block with a d16z6 head soon to get p28 ecu and tranny/manifold
Old Jan 10, 2007 | 11:46 PM
Default Re: (integraca)
all of them and i think you just gaved me the names thx ahaha
and does it supose to be lose?
Old Jan 10, 2007 | 11:47 PM
dustinO's Avatar
yeaaaa
im guessing your shift linkage pin (bitch pin) needs to be replaced.
have fun getting it out
Old Jan 10, 2007 | 11:50 PM
TwoKSiR's Avatar
Default Re: (slayerfromhell212)
If your shifter is moving back and forth to much it would be the other shift rod that has the problem. There is a rubber bushing where the ther shift rod linkage rod bolts to the tranny and one behing the shifter its self. Replace those with the energy suspension pieces and you'll be good to go.
Old Jan 10, 2007 | 11:52 PM
dustinO's Avatar
Default Re: (TwoKSiR)
chances are it's your shift linkage pin. not the stabalizer bar
Old Jan 10, 2007 | 11:54 PM
Timmay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoKSiR &raquo;</TD></TR><TR><TD CLASS="quote">If your shifter is moving back and forth to much it would be the other shift rod that has the problem. There is a rubber bushing where the ther shift rod linkage rod bolts to the tranny and one behing the shifter its self. Replace those with the energy suspension pieces and you'll be good to go.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayerfromhell212 &raquo;</TD></TR><TR><TD CLASS="quote"> i put energy suspension bushings the 1</TD></TR></TABLE>
unless its missing the bitch pin and just has a bolt or something in it .. your fine.. even with ES bushings my shifter still moved side to side
and bitch pins are easy to get out but im sure its fine
Old Jan 10, 2007 | 11:57 PM
dustinO's Avatar
ehh they are easy to get out if you have the proper tools. if not then your in for a world of ****. just get under there and start checkin stuff out. there is no easy "fix it" online answer for you my friend.
Old Jan 10, 2007 | 11:58 PM
TwoKSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraca &raquo;</TD></TR><TR><TD CLASS="quote">chances are it's your shift linkage pin. not the stabalizer bar </TD></TR></TABLE>
It could really be both. If theres any play in that pin then thats the problem. If theres no play its the bushings.
I had the same problem even after I got a short through. I thought that would help but it really didn't so I replaced the bushings the next day and I was golden.
While your ******* around down there replace the shifter. Get one on ebay for $20.
Old Jan 11, 2007 | 12:02 AM
Timmay's Avatar
egay shifters are trash.. everyone ive had made things worse.. i stick to oem now
bitch pins really dont go bad... so i highly doubt thats his problem.. most sohcs even with ES bushings still have play
Old Jan 11, 2007 | 12:07 AM
TwoKSiR's Avatar
Default Re: (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">egay shifters are trash.. everyone ive had made things worse.. i stick to oem now
bitch pins really dont go bad... so i highly doubt thats his problem.. most sohcs even with ES bushings still have play</TD></TR></TABLE>
Thats what I used to say buy I have a couple friends that are running them on b series with 3 to 4 years on them. One guy is running 11.92 on one so its getting hard shifts and s 4 years old. I shut up about them after that. But I love my JG Edelbrock short throw. But there not cheap in the world of shifters.
Old Jan 11, 2007 | 12:13 AM
Timmay's Avatar
yea JG isnt ebay though
for B series i love a nice stock integra shifter with ES bushings
Old Jan 11, 2007 | 12:19 AM
TwoKSiR's Avatar
True true. I picked it up at Battle from a vendor. It was his display piece but it was the last event of the year so I=he let it go for like $120 which was a steal at the time. Its alot like the teg shifter because it tilts back at the drive and over tword the driver if that makes any sense. Wouldn't trade it for anything.
And as for the energy suspension bushings, its some of the best money I have ever spent.
Old Jan 12, 2007 | 05:47 PM
i have gottne and type-r short shifter and i have replace the stock bushings with the energy suspention and i still get the little play so do you think i have to put a new bitch pin? if you have a link or anything on how to do the job tell me thx
jdmsir4dr
Jun 28, 2010 02:03 PM
itismejoshd
25
Sep 25, 2007 05:16 AM
whiteef-8
Oct 11, 2005 08:44 AM
goforbroke
Jul 29, 2005 08:39 AM
