spray paint on cf hood
Old Jan 10, 2007 | 10:28 PM
lalabooboo's Avatar
Default spray paint on cf hood
Some dumb *** people tagged up on my cf hood with iono and I wanted to know how could I remove or summin
Old Jan 10, 2007 | 10:38 PM
davidluko's Avatar
Default Re: spray paint on cf hood (kevin tegra)
Try buffing it off without going through the clearcoat.
Old Jan 11, 2007 | 12:12 PM
Sam92Teg's Avatar
tagged up?
You want to use the least aggressive means of cutting through the spray paint so you don't break through the clear coat too much. I would start with a mild rubbing compound and a buffer, or better yet, try just a polishing compound to start. If this doesn't cut thru it, which it should, then try a more aggressive compound, and lastly if the compound fails, try some 1500 grit wet-sand paper.
Once you get through the spray paint, reverse the steps back. If you had to go all the way to 1500 grit wetsand paper, then use rubbing compound, then polishing compound to remove the tiny scratchs, then use a cleaner wax, and then a nice sealant/wax. Remember, you want to use the least aggressive method as possible, maybe straight polishing compound will remove it.
Old Jan 11, 2007 | 01:17 PM
simbacivic's Avatar
Default Re: spray paint on cf hood (Sam92Teg)
that sucks.. sorry to hear it
Old Jan 11, 2007 | 06:50 PM
Big Bang's Avatar
wd-40
Old Jan 11, 2007 | 07:40 PM
PACT man's Avatar
Default Re: spray paint on cf hood (The Converted)
Lacquer thinner...
Old Jan 11, 2007 | 10:06 PM
95teg_ls's Avatar
Default Re: spray paint on cf hood (PACT man)
bug and tar remover, or goof off or stuff like that.
Old Jan 12, 2007 | 08:51 AM
gsr dood's Avatar
Default Re: spray paint on cf hood (95teg_ls)
i work at body shop. heres wat u do. take laquer thinner....he quicker u buy this stuff the easier it will be to come off. laquer thinner will completly erase un-cured paint then follow with a wetsand, compound, polish
Old Jan 12, 2007 | 02:44 PM
qwk db8's Avatar
i say put some jasco paint remover on it by the way jasco taste good to.jk try buffing it or maybe hit it with some 1500 or 2000 grit wet then try buffing
Old Jan 12, 2007 | 03:05 PM
jdm_bones's Avatar
Try googone!
Old Jan 12, 2007 | 03:19 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: spray paint on cf hood (jdm_bones)
**** and vinegar
Old Jan 12, 2007 | 08:48 PM
ANYTIME's Avatar
I would try some graffiti remover or some lacquer thinner (with first trying under the hood to make sure it doesn't screw up the finish) If not, I am looking for a hood for my track rat, with graffiti being OK.
Old Jan 12, 2007 | 10:22 PM
0260MOTORSPORTS's Avatar
Hit it with the finest RUBBING COMPOUND then buffit out with polish..Chemicals will dull the clear..OR even like 2000 2500 sandpaper and dip it constanly in water to wet sand
Old Jan 13, 2007 | 04:08 AM
RedB20DA's Avatar
Default Re: (0260MOTORSPORTS)
Most CF hoods come with a gel coat, not a clear coat.The gel coat is much softer use something like googone first Laquer thinner is the last option here, a good buff job and a very smooth rubbing compound will get it off eventually,it will take a while but go slow and dont stay in one section too long or you will ruin it.go over it once or twice then let it cool then repeat.
Old Jan 13, 2007 | 08:02 AM
GSRNetics's Avatar
Default Re: (RedB20DA)
I work at a detail shop, and my experience with Spray paint would be to use Meguiars Dual Action Cleaner/Polish #83. A DA sander or rotary buffer with Meguiars Cutting Pad should pull it off. On a scale of 1-10 on the cut for the polish compound is 6. Follow with a good swirl free polish (Meguiars #82, cut is at 3) with a polish pad, and then a glaze if you wish with a finishing charcoal pad.
If you've never used a rotary buffer I would suggest using the DA (Dual Action) Sander with your cutting/polishing pads. If you don't have any of that stuff, a stop at your local detail shop can fix the problem.
demon_camber
Paint and Body
70
Jan 3, 2013 04:57 AM
blb2397
Paint and Body
27
Jun 4, 2012 11:23 AM
sleepingeg6
Nov 28, 2005 08:54 PM
el_Presidente
May 27, 2003 12:10 PM
Urban Business
May 24, 2002 05:05 AM
