B18a B18b Rods and crank the same ???
Old Jan 10, 2007 | 09:48 PM
eg4life1202's Avatar
Default B18a B18b Rods and crank the same ???
i am rebuilding my spun bearing gsr motor
i'm looking into using a LS crank and Ls rods to replace the old ones from my gsr
does it matter if the rods came from a b18a or b18b and the crank i'm using is from a b18a ???
are all LS internals the same between b18a's and b18b's ???
my setup will be type r pistons on ls rods and a ls crank in a GSR block
Old Jan 11, 2007 | 12:27 AM
Ruben19's Avatar
same.
make sure to upgrade your rod bolts. use arp
Old Jan 11, 2007 | 04:54 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">same.
make sure to upgrade your rod bolts. use arp</TD></TR></TABLE>
nyceli
Mar 11, 2009 09:32 AM
joshc697
Oct 12, 2008 11:19 AM
rough_draft
Sep 13, 2005 09:33 PM
cygnusX1
Nov 10, 2004 01:02 PM
TspEk9
May 14, 2004 02:39 AM
