engine help?
Old May 14, 2002 | 08:08 PM
y2ks2k's Avatar
Default engine help?
Just finished putting my b16. my Q is the engine keep reving by itself. up and down. any ideas?
Old May 14, 2002 | 08:09 PM
DragII's Avatar
25 Year Member
Default Re: engine help? (slow_a$$_si)
vac leak or worn distributer
Old May 14, 2002 | 08:27 PM
flat-blk-HB's Avatar
Default Re: engine help? (SuperDragII!!!)
Any CEL's???
y2ks2k's Avatar
someone told me that there is air in the radiator hose? comments drag?
Old May 14, 2002 | 08:28 PM
y2ks2k's Avatar
Default Re: engine help? (ED6)
wuts CEL?
Old May 14, 2002 | 09:03 PM
DragII's Avatar
25 Year Member
I doubt that would have anything to do with it.
if it makes you feel better, squeze out all the air from the upper rad hose.
recheck all vac connections.
check engine light on?
Old May 17, 2002 | 11:08 PM
glagola1's Avatar
If there is air in the cooling system the coolant temp sensor can not do it's job. It wants to see a warm temp in the coolant to drop the idle. If air passes over the sensor it reads cool and confuses the ECU. As soon as it reads the hot coolant it lowers revs. That's why it fluctuates. Make sure to bleed and properly fill the coolant system. This will cure your woes no doubt.
JaguarS4R
Honda Civic (2001 - 2005)
12
Feb 28, 2010 04:12 PM
Circaskaterr
Feb 1, 2010 10:59 PM
greenhatchy
May 18, 2007 05:27 AM
street_ride14
Apr 22, 2007 06:43 PM
1.8T_EG
Oct 28, 2002 04:17 PM
