retuned my b16a, 257whp
Old Jan 10, 2007 | 08:09 PM
crx=si's Avatar
Default retuned my b16a, 257whp 169 ft/lbs tq
my car ran like craps since last time I tuned with the new intake manifold (TWM ITB originally on the motor), turned out the chip went bad (I guess after too many times reflash, sst 27sf512), so I decided take the car to the dyno and retune it, here's the graph
Modified by crx=si at 6:49 PM 1/11/2007
Old Jan 10, 2007 | 08:13 PM
92TypeR's Avatar
FSAE
Default Re: retuned my b16a, 257whp 169 ft/lbs tq (crx=si)
Good torque for 89mm
What manifold did you go with? Race gas I presume?
Old Jan 10, 2007 | 08:17 PM
crx=si's Avatar
Default Re: retuned my b16a, 257whp 169 ft/lbs tq (92TypeR)
the motor is 86 x 89, and yes the car was tuned on 110, 84 x 89 was my other old motor..., here's the old thread
https://honda-tech.com/zerothread?id=1780228
and I made the intake manifold
Old Jan 10, 2007 | 08:24 PM
SMSP's Avatar
Are those STD, SAE or Uncorrected numbers?
Old Jan 10, 2007 | 08:26 PM
crx=si's Avatar
Default Re: retuned my b16a, 257whp 169 ft/lbs tq (SMSP)
uncorrected numbers sir
Old Jan 10, 2007 | 08:27 PM
williejohnson's Avatar
New User
sorry for the noob question
what is the advantage of locating the throtle body where you did
Old Jan 10, 2007 | 08:30 PM
ABK's Avatar
ABK
Default Re: retuned my b16a, 257whp 169 ft/lbs tq (williejohnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williejohnson &raquo;</TD></TR><TR><TD CLASS="quote">sorry for the noob question
X2. What are the effects of that?
Old Jan 10, 2007 | 08:39 PM
crx=si's Avatar
Default Re: retuned my b16a, 257whp 169 ft/lbs tq (ABK)
the intake charge will have more time to travel to the runners, which in turn produce more laminar air flow, also taking the full advantage of the velocity stack as the car travel down the track
Old Jan 10, 2007 | 08:54 PM
HAMSTERHONDA's Avatar
the car is beyond great, seen it in person,
im jasons friend the army green hatch at face off,im gonna be needing to get tuned pretty soon, awsome numbers
Old Jan 10, 2007 | 08:58 PM
LSVTEC 91 Civic's Avatar
Banned
Sick B16
Old Jan 10, 2007 | 09:07 PM
ABK's Avatar
ABK
Default Re: (LSVTEC 91 Civic)
so lets say you make intake pipe that relocated your TB all the way down and use it with your current matifold you would gain power?
Old Jan 10, 2007 | 09:16 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx=si &raquo;</TD></TR><TR><TD CLASS="quote">the intake charge will have more time to travel to the runners, which in turn produce more laminar air flow, also taking the full advantage of the velocity stack as the car travel down the track</TD></TR></TABLE>
Time has nothing to do with flow being laminar.
87sivtec's Avatar
That's a huge top end. 8100-9500+ rpm is over 250whp! Sick! Nice work on the manifold as well.
Take it to the track now and see how it performs.
Old Jan 10, 2007 | 09:21 PM
crx=si's Avatar
Default Re: (ABK)
I'm not sure what will happen to your power if you just move the throttle body from your current intake manifold
Old Jan 10, 2007 | 09:26 PM
crx=si's Avatar
Default Re: (87sivtec)
the car went 11.56 @ 117mph with 240whp when it equipped with the TWM, so yeah I'm can't wait to run this
Old Jan 10, 2007 | 10:00 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">Time has nothing to do with flow being laminar. </TD></TR></TABLE>
Old Jan 10, 2007 | 10:16 PM
ABK's Avatar
ABK
Default Re: retuned my b16a, 257whp 169 ft/lbs tq (Combustion Contraption)
so does it have any positive effects on it? Or leaving your TB in stock location is more effective?
Old Jan 10, 2007 | 10:49 PM
GarageAlchemist
Guest
Posts: n/a
roflo.. you just made like 300 other stroked out engine builds look st000pid.
love it.
Old Jan 10, 2007 | 11:06 PM
crx=si's Avatar
Default Re: retuned my b16a, 257whp 169 ft/lbs tq (GarageAlchemist)
this is the previous graphs before I retune the car, this graphs are the intake manifold vs TWM ITB, the 249whp is the intake manifold
Old Jan 11, 2007 | 01:23 AM
hondaboyB18C1's Avatar
sweetintakeplenum , where do you get them??
Old Jan 11, 2007 | 04:09 AM
SMSP's Avatar
Default Re: (hondaboyB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboyB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">sweetintakeplenum , where do you get them??</TD></TR></TABLE>
He said he made it.
Old Jan 11, 2007 | 05:43 AM
Forrest Gump 9's Avatar
Default Re: (SMSP)
That's intake manifold is unique. Nice number too.
Old Jan 11, 2007 | 11:59 AM
crx=si's Avatar
Default Re: (Turbo9Nut)
here're some more pics of the IM
Old Jan 11, 2007 | 12:20 PM
BlackLudeSi's Avatar
Default Re: (crx=si)
Did you play with your runner length at all? Just curious they appear to be much shorter than most IM's. Looks very nice
Old Jan 11, 2007 | 01:07 PM
The_Head's Avatar
Why you'd use a B16A block when you have the exact same bore and stroke of a B20?
