shift linkage????
Old Jan 10, 2007 | 07:55 PM
hellracer24's Avatar
Default shift linkage????
i bought a 91 crx with a 93 ls motor and it is in need of new shift linkage. the linkage thats on there is cut and put back together with some kind of pipe and a nut and bolt on both ends to keep it in place. i'll post a pic soon. so i'm trying to find out what linkage i need that fits this swap? thanx in advance.
Old Jan 10, 2007 | 08:16 PM
::AnGeL::EF9's Avatar
Default Re: shift linkage???? (hellracer24)
u need to buy a special linkage made by hasport or any other company....but its a special made linkage....or u can do it the ghetto way and get a 90-93 integra linkage and cut it and weld....
Old Jan 10, 2007 | 08:21 PM
Default Re: shift linkage???? (::AnGeL::EF9)
cool thanx and here go a pic of what i'm dealin with....
Old Jan 11, 2007 | 11:14 AM
DC_RaceR's Avatar
works the same way as welding it, I guess it was just a difference idea. but like the person before said.
Old Jan 11, 2007 | 06:35 PM
Default Re: shift linkage???? (DC_RaceR)
its up to u either buy one or make one...
Old Jan 12, 2007 | 11:02 AM
Fezzie's Avatar
dunt make 1 do it right and buy it hasport.com sells shiftlinkage
Old Jan 12, 2007 | 08:32 PM
Default Re: shift linkage???? (fezzie)
true that do it right but if u dont have the cash what else can u do....
Old Jan 12, 2007 | 09:27 PM
sneakerfern's Avatar
gonna cut mine tomorrow... hope my welding is on point...
Old Jan 13, 2007 | 05:56 PM
Default Re: shift linkage???? (sneakerfern)
yeah i'll buy one later on but welding is fine for now thanx guys
Old Jan 13, 2007 | 10:10 PM
abnaasefmb's Avatar
If you don’t have a welder go ahead a buy some $150 linkage. However you’re wrong if you have some kind of idea the welded linkage is some how inferior. As long as you do it right it’s the same ****. Since I’ve done a few swaps and h-motors is always nice enough to include linkage, I’ve got this down. The key is to make sure the final product is lined up properly.
Tools needed:
Speedy-grinder
Welder (you can rent this at the home depot)
Sharpie
Spray paint
What you do:
1. take the teg linkage, and take it apart.
2. with your speedy-grinder, grind off all the undercoating and paint over about 10 inches until it’s all shiny all the way around. This is done on the longest straight part of the linkage.
3. take some kind of straight edge and make 2 lines on the new shiny surface. Put hash marks on one line. The lines should be about 180* from each other. So one line looks like this ________ and the other looks like this -/-/-/-/-/-/-/ you get the idea. They need to be as long as possible.
4. now mark out 2 3/8” some where in that section.
5. cut it out the 2 3/8” section.
6. align the lines back up _____ -/-/-/-/-/-/ this makes everything true.
7. weld
8. paint
9. repeat with the other bar.
Old Jan 14, 2007 | 01:51 PM
Default Re: shift linkage???? (abnaasefmb)
tight thats the **** thanx alot that help a whole lot
Old Jan 14, 2007 | 01:55 PM
betsy84's Avatar
A better way to weld up linkage and such like that is to take a pipe that has the same ID as the linkage does OD, drill holes in it and plug weld it. It acts like a sleeve *edit* Then weld each end up. This way, even if you have to hammer in the linkage, you know its going to be straight.
Modified by betsy84 at 7:47 PM 1/16/2007
Old Jan 14, 2007 | 02:07 PM
KaoticSnow's Avatar
http://www.hasport.com/products/linkage.htm
this is the linkage I have at the moment with my swap setup, love it.
Wes V's Avatar
Default Re: (betsy84)
Hasport makes some good stuff, but there is <U>nothing</U> wrong (or getto) with cutting and welding linkage!!
Plus there is the fact that if you don't have Hasport mounts, different engine placement may cause the Hasport linkage to not work correctly!
Here is a write-up on how I did it;
http://www.performanceforum.co....html
Wes
Old Jan 17, 2007 | 04:16 PM
Default Re: (Wes V)
thanx you guys are the ish
historic4thewin
Jun 6, 2013 12:02 PM
slowcrx954
Sep 18, 2007 06:11 AM
eric.lscrx
Sep 21, 2005 11:32 AM
BLUE EH3
Aug 30, 2004 10:10 PM
CRX_GUY_123
14
Apr 5, 2004 09:13 AM
