Aftermarket LCA's
I was just wodering about the aftermarket LCA's. What advantages besides weight do they give you? They say they are stronger. Will they let me add a sway bar with less hassle? I know the rear LCA's are interchangeable from 88-95 but are the front? These are what I was looking at.http://www.modacar.com/product...ACOA/ The omni power ones.
well I got SRR ones that have no bushing at all in them they have spherical bearings
they were about the price of those omni ones too. the weight and strength arent that much different than stock maybe a pound or 2 and I dont know how much stronger they are either, they are mostly bling. unless you get some hardcore bearing ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N_A_is_best »</TD></TR><TR><TD CLASS="quote">no body makes the fronts for an ef yet </TD></TR></TABLE> I didn't ask if they make them for ef's, I asked if they the eg front's could be used. The reason i'm looking at these is for the sway bar mounting, seeing how the base ef hatch didn't come with any.
yes the eg ones work that what I have on now, I also have 2 sets of stock si LCA(with the sway bar mount), tell me if you want a set. one set the bushing are messed up in and the other set has pretty new poly bushings in them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">yes the eg ones work that what I have on now, I also have 2 sets of stock si LCA(with the sway bar mount), tell me if you want a set. one set the bushing are messed up in and the other set has pretty new poly bushings in them</TD></TR></TABLE>
How much for the set with the polys?
GI8U2racing
13
Dec 20, 2006 08:47 PM
