radio block off plate
No problem. Just be carefull cutting it because the plastic is thin and can break easily. The plate also has clips and stuff on the backside that might get in the way of the gauges. I used a dremel with a grinding stone to grind/melt away the plastic and I think mine turned out very good once the gauges were in place.
