mpfi nightmare
Old Jan 10, 2007 | 04:44 PM
nk2k2's Avatar
Default mpfi nightmare
okay so i got my mpfi done. car had misfire/backfire/sputter/ran rich and had a code 9. took it to shop, they charged me two hours of diagnostic which was 75/hr plus 12 shop fee which came to 162. after that they said they need to re-wire everything because it wasnt wired right. so they charged me 3 hrs for 75/hr. Then they determained that the distributor was bad and they called up telling me that it was 290 for a new ones. did that and they called me back and said the car is running good and i can come pick it up. after 560 plus odd change, the CEL was gone but the car still ran like ****. The shop closed so ill have to take it back tommorow. Im so pissed right now about this. After close to 600 bucks plus the 150 for the mpfi, the car still runs like ****. The worst part is, i have to take this car to work tommorow and i dont know if it is safe or not. i dont want to get stuck.
Main part: how in the world do i fix this running like **** issue?
Old Jan 10, 2007 | 06:45 PM
janz3n's Avatar
Default Re: mpfi nightmare (4g4d)
wow this has turned into a nightmare for you.. you can still drive the car if its not too bad.. cuz i did for a couple days. but im pretty sure its jsut a wiring problem man. just redo all the wiring. may take a wile but try it.. smoke a joint before you do it so your not so mad and screw it up. lol
Old Jan 10, 2007 | 08:44 PM
Rywire's Avatar
Default Re: mpfi nightmare (janz3n)
Rywire FTW Pm me if you have a specific question for me
Ryan
Old Jan 11, 2007 | 03:06 AM
jackinthetrunk's Avatar
Default Re: mpfi nightmare (droppedcrxsi)
bah, someone should really make an updated MPFI walkthrough, I would probably pay a lil fee for that info. Im about to start doing mines and it doesnt seem that hard to do. The only thing that has my buging right now is that Im going to put obd1 injectors and there aint much explanation on that.
Old Jan 11, 2007 | 03:31 AM
s10cky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Rywire FTW Pm me if you have a specific question for me
Ryan</TD></TR></TABLE>
yea, I spent around 300, plug and play. cant beet it.
Old Jan 11, 2007 | 04:04 AM
dr_latino999's Avatar
Default Re: mpfi nightmare (jackinthetrunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackinthetrunk &raquo;</TD></TR><TR><TD CLASS="quote">bah, someone should really make an updated MPFI walkthrough, I would probably pay a lil fee for that info. </TD></TR></TABLE> Why? It's not like any of the information has changed.
Old Jan 11, 2007 | 06:23 AM
dohc_profile's Avatar
go buy a sohc zc. i know that doesnt fix your problem now, but instead of trying to fix it. buy a motor and harness that has mpfi.
Old Jan 11, 2007 | 05:31 PM
Default Re: (dseries_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dseries_ef &raquo;</TD></TR><TR><TD CLASS="quote">go buy a sohc zc. i know that doesnt fix your problem now, but instead of trying to fix it. buy a motor and harness that has mpfi. </TD></TR></TABLE> How would that help? The only difference on the motor electronically is the IM and Distributor, which he has, and the MPFI harness would not plug into his car thanks to the shock tower connections.
Old Jan 11, 2007 | 05:39 PM
janz3n's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky &raquo;</TD></TR><TR><TD CLASS="quote">
yea, I spent around 300, plug and play. cant beet it. </TD></TR></TABLE>
im sorry but 300 dollars seems pretty high for a harness.. doesnt seem worht it to me when all it is is a few wires moved and some new ones put in. took me no time to do.
Old Jan 11, 2007 | 07:21 PM
1slowEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">wow this has turned into a nightmare for you.. you can still drive the car if its not too bad.. cuz i did for a couple days. but im pretty sure its jsut a wiring problem man. just redo all the wiring. may take a wile but try it.. smoke a joint before you do it so your not so mad and screw it up. lol</TD></TR></TABLE>
Amen to that haha
Old Jan 11, 2007 | 07:28 PM
Scotland:EF3's Avatar
who want to help me with mine, anyone want to lend a hand???? maybe some money for help.
Old Jan 11, 2007 | 07:33 PM
ludesrv's Avatar
Default Re: mpfi nightmare (1slowEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowEF9 &raquo;</TD></TR><TR><TD CLASS="quote">
Amen to that haha</TD></TR></TABLE>
I'm freaking high right now lol.
Quad-million check your wiring. Sounds like the timing might be off too. If you get a chance get it timed. Takes no time at all with a good timing light and a 12 mm wrench. Might aswell rule it out as an option. If your dizzy is fully retarded it will run like shiiiit.
Old Jan 13, 2007 | 10:22 AM
Rywire's Avatar
Default Re: (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">im sorry but 300 dollars seems pretty high for a harness.. doesnt seem worht it to me when all it is is a few wires moved and some new ones put in. took me no time to do.</TD></TR></TABLE>
I totally dont agree with you. 100 is for the ecu jumper, the other 200 is for reshaping the harness so its all plug and play. My harnesses look brand new when they are done, honestly you cant even say that untill you have seen one/ used one. People always rag on me for my prices, why? Its cheaper than hasport, and cheaper than ebay if you add up the cost and time of modding the lame *** harnesses on there to run obd1. Its a cheap and ez solution
Also...
It takes me about 2 hours to make a harness (not including the time for a ecu jumper), and ive built 1,500+ dpfi to mpfi's and I do them FAST! I crimp on pins to make it faster(to cut solder time), and add new wires... Sure, anyone can run a wire back to the ecu in like 30 minutes be almost done, but this is not that type of harness, nothing is half-assed.
Old Jan 13, 2007 | 01:28 PM
civhatch90's Avatar
after it was running like ****, did you take it to a random shop? apparently they did not do a good job. that seems to be a mistake since you dont really know what they did to the car.
im sure there is somewhere you know or around you that can stop by and take a look at the wiring on the car, thats your best bet
Old Jan 13, 2007 | 01:44 PM
Blown90hatcH's Avatar
Default Re: (droppedcrxsi)
Also...
It takes me about 2 hours to make a harness (not including the time for a ecu jumper), and ive built 1,500+ dpfi to mpfi's and I do them FAST! I crimp on pins to make it faster(to cut solder time), and add new wires... Sure, anyone can run a wire back to the ecu in like 30 minutes be almost done, but this is not that type of harness, nothing is half-assed.</TD></TR></TABLE>
Your prices are outrageous! We are Honda owners in case you didn't notice j/k
Look at how many "WTF", "mpfi nightmare", "butt raped by my mpfi conversion"...bla bla bla threads there. Unless you are certain you can do it, just save up to get the mpfi harness. The many hours saved, guaranteed results, etc. is well worth it the first time around.
Old Jan 13, 2007 | 01:50 PM
janz3n's Avatar
Default Re: (Blown90hatcH)
im sorry but 300 is way too much for a harness. i kown theres lot of mpfi nightmare posts but i did mine myself and it turned out perfect. after i figured out what was wrong. im sure if someone wants there wiring to look stock then its a good deal.. but i just dont care about the look. i care about functionality
Old Jan 13, 2007 | 04:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">im sorry but 300 is way too much for a harness. i kown theres lot of mpfi nightmare posts but i did mine myself and it turned out perfect. after i figured out what was wrong. im sure if someone wants there wiring to look stock then its a good deal.. but i just dont care about the look. i care about functionality</TD></TR></TABLE>
300 includes the pre-obd (OBD0) to OBD1 conversion harness too.
Old Jan 13, 2007 | 05:09 PM
91tegrals's Avatar
i would have to say unless you know wat you are doing then then 300$ is a good price to pay for ease of instalation. and i have bought a rywire harnesse and it was perfect i never did get to use it but it was neet and clean..i reacently did my own and it is not hard if you have any sense at all and can follow directions and i would be more than happpy to help you guys that are having probs as much as i can...
Old Jan 13, 2007 | 08:33 PM
NikoZai's Avatar
Default Re: (91tegrals)
My 2 cents is that we have quite a few loyal shops that send all their wiring to us because they know, without a doubt, they won't have a problem. They pay their techs more to build a harness then they do US and they trust us more.
Look at how much this guy paid to have a shop diagnose it - I DO THAT OVER THE PHONE FOR FREE and it takes a hell of alot less time than 3 hours. I could have an amature figure the **** out himself in 30 minutes on the high side. Ryan and I are daaamn good at that - I've spent 15 minutes teaching someone how to use a volt meter just to continuity check a few wires and switch their positions. Customer educated, problem solved. That's the true value of our services - you won't be left hanging forced to go to some overpriced slow shop.
civickiller
Jan 7, 2007 01:34 AM
90jdmcrxdude
Apr 29, 2006 04:21 AM
daklown
15
Jun 5, 2005 10:37 AM
1998IntegraLS84
May 13, 2005 01:00 AM
the niz jiz
47
Feb 27, 2005 10:33 PM
