Bumping up compression... need Engine mang???
Old Jan 10, 2007 | 10:24 AM
teg01type-r's Avatar
Default Bumping up compression... need Engine mang???
this is prolly a stupid questiong but im putting CTR pistions in my ITR b/c my piston rings are shot and i might want to do engine work later down the line. would i need any kind of engine management to do that or would stock ecu be ok?
Old Jan 10, 2007 | 11:24 AM
andyt's Avatar
Default Re: Bumping up compression... need Engine mang??? (teg01type-r)
I dont really know the answer to your question, but FWIW I just bought an ITR that had CTR pistons, everything else stock, and he was running 94 octane and using a Kenji ecu.
I'm going back to stock so I'm selling the pistons, ECU, etc...
Old Jan 10, 2007 | 11:33 AM
Casey's Avatar
Default Re: Bumping up compression... need Engine mang??? (andyt)
i would recommend another piston all together. The ctr piston is heavy, has a high dome which basically separates the combustion chamber, and will yield a compression of 12.5:1 or a little higher when used in the b18c5 assuming everything else is stock.
If you want to bump your compression, Id go with jdm b16 pistons, they will raise it but itll be around 12.0:1 and with less dome.
I would definitely recommend some dyno tuning with a wide band when raising the compression that much, especially if you want to get the most out of it as well as preventing detonation.
Old Jan 10, 2007 | 02:54 PM
L_K's Avatar
L_K
Default Re: Bumping up compression... need Engine mang??? (Casey)
i m in the same process and just wondering where could i find the jdm b16 piston? honda?
Old Jan 10, 2007 | 04:25 PM
doood's Avatar
been there done that
Default Re: Bumping up compression... need Engine mang??? (L_K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L_K &raquo;</TD></TR><TR><TD CLASS="quote">i m in the same process and just wondering where could i find the jdm b16 piston? honda?</TD></TR></TABLE>
http://www.hmotorsonline.com
Old Jan 12, 2007 | 08:09 AM
L_K's Avatar
L_K
what would the compression be if i use the usdm b16 piston instead of the jdm??
Old Jan 12, 2007 | 04:43 PM
MK Ultra's Avatar
USDM B16A2 pistons should put your B18C5 at around 11.3:1 CR.
JDM SiR II pistons will give you 11.5:1.
Assuming everything else is stock, that is.
I wouldn't want to run compression that high without some ecu tuning, myself.
johnzm
566
Mar 19, 2013 05:13 AM
B16A CRX
Apr 6, 2007 06:03 AM
KillaB-
Sep 19, 2004 06:01 PM
hondacrx90
Jun 21, 2004 06:06 PM
JBk24crx
Aug 6, 2003 11:26 PM
