new to boost, couple quick questions, they arent that stupid :thumbup:
Old Jan 10, 2007 | 09:37 AM
xDicktonesx's Avatar
Default new to boost, couple quick questions, they arent that stupid :thumbup:
is there anyone who makes pre-fabbed supply and return oil line kits that maybe even come with the taps for the pan?
also, i have a set of dsm 450s. i understand i need a resistor box. i have an obd0 harness, c an i just unplug the dummy plug i have and plug in the stock honda obd0 resistor box i have laying around? or do i need to wire in a dsm resitor box or something crazy.
thanks a bazillion.
Old Jan 10, 2007 | 10:06 AM
firetech's Avatar
Default Re: new to boost, couple quick questions, they arent that stupid :thumbup: (xDEFTONESx)
Check out http://www.race-lines.com for the oil lines, I know they do free shipping and I am pretty sure they were running a special.
As far as the resistor box goes I think this writeup will tell you everything you need to know - https://honda-tech.com/zerothread?id=736737
Old Jan 10, 2007 | 12:05 PM
93turbo16's Avatar
also check http://www.stealthmodeperformance.com for the oil lines.
Old Jan 10, 2007 | 12:20 PM
Default Re: (93turbo16)
from the looks of it, i can jsut plug my resistor box back in.
basically you jsut need to take the injectors from 12V to 4.5V right?
Old Jan 10, 2007 | 01:50 PM
93turbo16's Avatar
Default Re: (xDEFTONESx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">from the looks of it, i can jsut plug my resistor box back in.
basically you jsut need to take the injectors from 12V to 4.5V right?</TD></TR></TABLE>
Actually you are decreasing the current draw. So you don't overload the injector drivers in the ecu.
Old Jan 10, 2007 | 03:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
Actually you are decreasing the current draw. So you don't overload the injector drivers in the ecu.</TD></TR></TABLE>
so, correct me if i am wrong, but if am running an obd0 chassis harness and the engine harness is converted to obd1 and im on a p28, i can unplug the dummy plug i have in the old resistor box plug, plug in the honda resistor box, and insert dsm 450s and crome will read them jsut like obd1 honda injectors?
jne
Feb 8, 2010 10:23 AM
Slow Ek
Sep 2, 2008 04:26 PM
Homotor
Dec 14, 2007 12:29 PM
RACEPAK
Jul 20, 2005 12:40 PM
redboost10
Oct 23, 2003 03:35 PM
