tires rubbing
Old Jan 10, 2007 | 09:33 AM
duyfash0's Avatar
Default tires rubbing
I just dropped a gsr motor into my 99 civic hatchback and now the front passnger side is rubbing like crazy when i make a turn. I droped the car with eibach sportline springs and it didnt rub b4 the swap. The driver side isnt have any kinds of problems and driving smooth. I know the gsr motor is heavier then the factory motor but why is only one side rubbing? should i get differernt springs? help!
Old Jan 10, 2007 | 09:35 AM
WhiteOnRice's Avatar
That is strange because you would think the driver's side would be lower because the engine is heavier than the tranny. The struts have probably had it. Upgrade
Old Jan 10, 2007 | 11:59 AM
MidwestSiR's Avatar
blown shocks COULD be it... maybe your springs have just sagged because of the weight difference?! Sounds odd
Old Jan 10, 2007 | 12:01 PM
kaiba's Avatar
Default Re: tires rubbing (duyfash0)
roll the fender.
Old Jan 10, 2007 | 12:56 PM
jay_cue's Avatar
Default Re: tires rubbing (kaiba)
With sportlines, you shouldn't rub. What size tires are you running?
I just dropped my 92 hatch with gsr swap on the same springs. Ended up rubbing just cuz I had the front lca bent, and it was pushed back. Once I fixed it, no more rubbing
Old Jan 10, 2007 | 12:58 PM
Eran's Avatar
HT White Ops
I run a B18B with H&R Sports (almost identical drop) .... and I don't rub.
flyingduck04
Suspension & Brakes
Feb 24, 2012 12:32 PM
honda_student
Suspension & Brakes
Apr 27, 2008 03:17 PM
93formula
Jun 6, 2007 08:29 AM
anderbud
Dec 29, 2004 04:02 PM
crazyteg
May 19, 2002 01:58 AM
