Changing oil in Honda Prelude h22a vtec, how many quarts of oil, and the best oil to use for colder
hey guys i know this is a dumb simple question but how many quarts of oil do i put in an h22a honda prelude engine, also what is the best oil for altering from say 20 degree weather to 60 degree weather...let me know thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu »</TD></TR><TR><TD CLASS="quote">Try Mobil 1 0w-40. Just switched and love it.</TD></TR></TABLE>
thats the euro fomula.
0-w20 made for honda
the better the oil the less it burns it self up.
i fould that 0-W20 burns the less.
after a long hard drive i would open the oil cap and see no smoke at all
with 5-w30 their is smoke.
(smoke meaning burning oil in the crank case from the heat and friction of a hard run engine)
i will switch to torco 5-w20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacticalcustoms »</TD></TR><TR><TD CLASS="quote">Honda only recommends using 5w-30 no matter what season.. So I think I'll stick with using 5w-30 all year with mobil 1 full syn :D</TD></TR></TABLE>
if you read the back of a mobile 1 o-w20 it states that they worked with honda to devolop this formula
its oem in the k engine. remimber that it wasn't around when they wrote the service manuel for the h22
thats strange. then I wonder why honda still would use and insist on using 5w-30 if 0w-20 is so much better..
http://www.ahm-ownerlink.com/M...atoil
Refer to your owner's manual to determine the proper weight (viscosity) grade for your Honda . Your vehicle was designed to use this specific weight grade. Confirm that the weight listed on your oil's label matches this recommendation exactly before using it in your engine.
so if my h22a was specifically designed to use 5w-30. then thats what I will continue to use.
5-w30 mobile one syntec is great oil that what i use in my hyundia sonota.
i used to run 5-w30 in my honda untill i tried 0w20 one time at a oil change.
i seen it for the first time and a couple years ago and i keep on using it.
either way
mobile 1
Modified by alterdcreations at 5:11 PM 1/10/2007
either way
mobile 1Modified by alterdcreations at 5:11 PM 1/10/2007
yea thanks guys we just put in another quart today running good, i use 5w-30 mobil 1 in my ls/vtec, she insists on castrol syntec in her prelude so thats what i put in, i believe in mobil 1 all the way, what is this new 0-20w i was reading up on it sounds new and very good for the vtec, since vtec demands more oil when engaged, thanks for the tips though guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations »</TD></TR><TR><TD CLASS="quote">
0-w20 made for honda</TD></TR></TABLE>
True. In Europe they actually use 0w-40 in Preludes. Yes the dealership!
True. In Europe they actually use 0w-40 in Preludes. Yes the dealership!</TD></TR></TABLE>
yeap. I've always use the mobil1 superSyn 0w40 and i'm verry happy with it. Even back then when i was driving my old corolla with a 1,6L single cam curb engine and beating the hell out of it .Few days before i sold it i pull the head off and i was surprised about the good contition of the internals. it was a 200k (km not miles) motor and it was looking like a 20k
I've pulled the head off my 182k h22 just a week ago for a timing belt change and i was expecting a little bad shape since i've run my motor for about 5 min with almost no oil at all few months ago when my oil filter snaped and loosing my oil in seconds without me realizing anything in time... still in perfect condition.
Now i'm using a castrol syntec for a week or so, just to give it a try since my new mechanic recomended it, but i'm not too excited about it. I'm swiching back to mobil1 on my next oil change
A 20 weight oil is a bad idea, that's thinner than stock. It's used in NEWER engines where manufacturers are trying to squeeze out every last bit of fuel economy from their engines.
In contrast, we drive engines that were put on paper over 15 years ago. And I'll assure my engine adequate lubrication by using an oil more in spec (30 weight) instead of hunting for a tiny increase in milage that may or may not work with my engine's design.
Plus our engines rip through oil as-is, going thinner would only make that worse.
Directed at the OP, if you're going to be doing lots of cold weather driving get a 0w-30 or 5w-30 oil.
