Distributor Question?
Old Jan 10, 2007 | 06:14 AM
webba1's Avatar
Default Distributor Question?
Ok Im trying to piece together an MPFI swap for my 90 dx hatch. So far I have everthing I need: Ecu (obdo), intake manifold, and resistor box. I need a distributor, will a stock obd1 distributor work or do I need the D16A6 distributor. If I need the A6 does anyone have one or know were i can find one (I know that last statement belongs in the marketplace and may be there soon). Any helps guys?
Old Jan 10, 2007 | 08:05 AM
crxnj's Avatar
Default Re: Distributor Question? (webba1)
you need the 88-91 d16a6 or d15b6 HF ..the obd1 distributor will work fine but you'll need an obd1 ecu like a p06 and also convert your cars wiring to obd1.
note if you get an obd1 piece dont get the d16z6 cause you have to rig it to fit,,but if you dont mind rigging get it.
Old Jan 10, 2007 | 08:20 AM
webba1's Avatar
thanks man. I actually have a P06 and a PM6 but im trying to do this as low buck as possible. to the marketplace I go.
worx
Oct 9, 2009 12:50 PM
kylesmith3251
Jan 18, 2009 01:52 PM
kylesmith3251
Jan 17, 2009 05:47 PM
SupraRXZ
Jan 8, 2006 10:37 AM
r7
Apr 26, 2003 10:38 AM
