throttle cable or throttle body???
hi everyone in my 1992 hatch the gas pedle was sticking when i would let go of the gas. when i would come to a stop i would have to kick it to free it up but i got in my car the other day and the gas pedle had so mcuh play so i thighed up the cable got in it hit the gas, it still gets stuck and now it gets stuck like have way is thsi the cable or the body or both thanks for your help.
i would first check the throttle cable for pinches...its prob getting stuck somewhere...happened to a DA i used to have...had a GSR and the braket that holds the cable was up high so everytime i closed the hood, i would put stress on the cable causing it to get fcked up and stuck by the little rubber boot...
uhm...well, im not sure yo, dont want u to go spend money on something you dont need...when i had that problem, it was my throttle cable, thats why i mentioned it...maybe someone can throw in their 2 cents on some ideas to this prob...
yea man, try taking your intake off and manually moving the throttle rotor and see if the TB butterfly gets stuck...if so, take it off and clean it with some simple green or something...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch »</TD></TR><TR><TD CLASS="quote">i cheacked that still doin it i cleaned the body and it still gets stuck i have no idea what to do should i get a new cable and try???</TD></TR></TABLE>
bingo.
but just FYI, things i would have checked as a list...
check the throttle body. have someone step on the gas while you watch your throttle body. Oil up the rotating disc as needed. Carb cleaner on the inside of the TB.
check under your dash for your pedals to see if everything is copacetic, bolts there tightened etc.
take out throttle cable and examine it. maybe you need a new one.
shouldn't be too hard of a fix.
bingo.
delamission
Jan 21, 2006 03:15 PM
rolledthatho
Sep 9, 2005 10:29 AM
