no coolant to radiator?
Old Jan 10, 2007 | 12:31 AM
Kafelatte's Avatar
Default no coolant to radiator?
me and my friend have been trying to figure out why there is no coolant returning to the radiator. the top hose feels warm but the bottom hose feels like ice. there's no water going back into the radiator. we repalced the thermostate, water pump, temp. sensor. could it be a blown headgasket because the oil is kinda watery but the coolant seems to be clean.? could it be the radiator? someone please help.
Old Jan 10, 2007 | 12:50 AM
sol2hatch's Avatar
Default Re: no coolant to radiator? (kay20adc2)
i assume that you let it warm all the way up, and that you have the right thermostat. you could also test that your thermostat is not defective. Does the oil have coolant in it? The oil will turn to crud and F your engine up if that is the case and you run it like that. Keep an eye on your oil if you think you might have a bad head gasket.
Old Jan 10, 2007 | 03:16 AM
mikeycivic's Avatar
Default Re: no coolant to radiator? (sol2hatch)
do you have heat?
Old Jan 10, 2007 | 04:13 AM
sr20power's Avatar
if there was coolent in the oil you'd know it would smoke up your whole neighborhood, i know
Old Jan 10, 2007 | 10:30 AM
Kafelatte's Avatar
bump
vartok
24
Nov 10, 2011 08:57 AM
pjg
Mar 8, 2010 03:50 PM
ssj4trunks09
19
Jan 13, 2008 04:21 PM
turbohb21
Sep 24, 2007 11:36 PM
noob101
Apr 27, 2006 05:09 AM
