type Sh swap in a 4th gen
Old Jan 10, 2007 | 12:05 AM
skylude23's Avatar
Default type Sh swap in a 4th gen
I recently purchased an h22a4 type SH for my 92 prelude si i was wondering if im going to need anything else to complete this swap i have the entire car its been wrecked and im parting it out i have everything im just wondering is it going to fit and my engine mount are busted so can i use the ones from the SH will everything fit ? also can i do a 5 lug conversion can i take the whole rotor assembly arms shocks everything and swap that too i have the 4ws on my 92 will i need to remove that in the rear and im thinking about doing a 5th gen front conversion to my 4th.
Old Jan 10, 2007 | 07:21 AM
GtechPro's Avatar
Default Re: type Sh swap in a 4th gen (skylude23)
I was going to answer that for you until I read this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylude23 &raquo;</TD></TR><TR><TD CLASS="quote"> and im thinking about doing a 5th gen front conversion to my 4th. </TD></TR></TABLE>
I figured, with all the money you'd end up spending on teH conversion you wouldn't have enough to do the swap.
Old Jan 10, 2007 | 10:08 AM
skylude23's Avatar
Default Re: type Sh swap in a 4th gen (GtechPro)
is it true that the motor will fit but the tranny wont can i use my h23 tranny on the motor
Old Jan 10, 2007 | 10:11 AM
roller3804's Avatar
yes you could use the h23 tranny. Any h series tranny will work. You could make make the sh tranny work with some modification.
Old Jan 11, 2007 | 01:19 AM
skylude23's Avatar
Default Re: type Sh swap in a 4th gen (roller3804)
will the type sh motor mount work? and will i need to do any wiring from the h23 tranny to the sh motor cuz its an obd1 tranny with an 0bd2 engine how will the ecu pick up the obd1 h23 tranny im using the sh ecu
Old Jan 11, 2007 | 02:06 AM
Revi's Avatar
You will not be able to use the H23 tranny. The ATTS unit will not go on the H23 tranny. If you want to use any tranny other than the SH tranny your gonna have to do the ATTS removal mod.
Old Jan 11, 2007 | 05:02 AM
WhiteBB2's Avatar
Default Re: type Sh swap in a 4th gen (Revi)
just use an SH tranny...
Old Jan 11, 2007 | 08:50 AM
kulrevon's Avatar
Default Re: type Sh swap in a 4th gen (WhiteBB2)
hes putting this swap in a 4th gen. why would he want to use the sh tranny. It would be to much work to wire in the atts unit and make it run right.
the easiest thing is to use the h23 tranny and the sh motor. I would use an obd1 ecu not the sh. and I would use all the h23 motor mounts.
everything will bolt right in. except for the intermediate shaft which I believe people have made these adaptors before.
Old Jan 11, 2007 | 09:02 AM
red92s's Avatar
Default Re: type Sh swap in a 4th gen (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't a SH block different than a standard H22 block?
Old Jan 11, 2007 | 10:10 AM
prelude1897's Avatar
Default Re: type Sh swap in a 4th gen (red92s)
the only way this swap will work is if you have the tranny, axles, atts unit, motor, ECU, ATTS computer, and rewiring a few things.....If there's something I'm missing, someone post up
Old Jan 11, 2007 | 10:21 AM
kulrevon's Avatar
Default Re: type Sh swap in a 4th gen (prelude1897)
he is putting it in a fourth gen. al he wants to use is the engine. and get the adapter plate for his intermediate shaft. use the 4th gen tranny and mounts.
simple and done.
no bullshit of adding atts which I have never seen done in a 4th gen. please show me if it has been done.
Old Jan 11, 2007 | 04:09 PM
yea, that'll work then if you're getting the adaptor plate
ge_itr
Jul 13, 2006 08:11 PM
blackludeH22
Apr 9, 2004 07:59 PM
RUBZERK
Mar 4, 2004 07:48 AM
n1_ek
Sep 25, 2003 07:27 AM
