what kinda MSD is this? and how do i remove it and get back to STOCK?
Old Jan 9, 2007 | 09:30 PM
CrazyRexBoy's Avatar
Default what kinda MSD is this? and how do i remove it and get back to STOCK?
hey guys...another tough one for me....when i bought my 99 GSR...it came with MSD...as far as asking around and having few people look at my car...they said its the MSD system that creates more spark.... i dont think i need it if i want to be stock and dont really race... does anyone know how to remove it?
here are details on this system...
red MSD box mounted near distributor
wire going to the distributor from red box
think black and red wire going from msd box all the way to inside the car
few red ground wires on valve cover going to radiator support
please help? i want to go stock ...i need a basic step on how to remove it ...
THANKS in advance again...
Old Jan 9, 2007 | 09:39 PM
Default Re: what kinda MSD is this? and how do i remove it and get back to STOCK? (CrazyRexBoy)
heres a link of what it looks like...
http://www.streetsports.com/Ph...p.jpg
i hope someone on here has the exact system and can give me answers...thanks...
Old Jan 10, 2007 | 10:37 AM
mc-integra111's Avatar
I can help out somewhat. I use an MSD SCI-L ignition box with a Blaster SS coil.
The red box next to your distributer is your coil (actually is the Blaster SS coil). The wires going inside of the car from the coil should go to the actual ignition box. You will need to find this box as well.
To remove MSD, you will need to remove both the ignition box and the coil. Then, you will need to add the stock ignition coil to the distributer. On Integras this is located inside of the distributer. To see this simply remove the distributer cap and look for a black box about half the size of the MSD coil. If this is not in the distributer, then you will need a new one. When adding this stock coil back, you will need to include the 2 wires that connect it to the distributer. I do not know this wiring, so you will have to find a Helms manual (or other) to figure out the wiring. The MSD website should have a schematic of their wiring, which may help.
95 integra's Avatar
Depends if they took the stock coil out or not, but basically you can either replace the old distributor w/ a new one (and remove the entire thing and sell it as a ready to run unit) or you can take the MSD red box and MSD external coil off, put a stock cap back on and generally you'll have to put the stock coil back in the distributor and/or hook it up w/ the wires. Some people leave it in there and splice the wires on the outside of the dizzy, others take it out and just hook to the wires in the dizzy. Thus, its hard to say exactly what needs to be done without actually seeing it.
Old Jan 10, 2007 | 10:41 AM
Default Re: what kinda MSD is this? and how do i remove it and get back to STOCK? (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">put a stock cap back on</TD></TR></TABLE>
95 integra has a point. I forgot to mention that you will need the stock distributer cap when using the stock coil.
Old Jan 10, 2007 | 11:59 AM
TurboGS-R's Avatar
Default Re: what kinda MSD is this? and how do i remove it and get back to STOCK? (mc-integra111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mc-integra111 &raquo;</TD></TR><TR><TD CLASS="quote">I can help out somewhat. I use an MSD SCI-L ignition box with a Blaster SS coil.
To remove MSD, you will need to remove both the ignition box and the coil. Then, you will need to add the stock ignition coil to the distributer. On Integras this is located inside of the distributer. To see this simply remove the distributer cap and look for a black box about half the size of the MSD coil. If this is not in the distributer, then you will need a new one. When adding this stock coil back, you will need to include the 2 wires that connect it to the distributer. I do not know this wiring, so you will have to find a Helms manual (or other) to figure out the wiring. The MSD website should have a schematic of their wiring, which may help.</TD></TR></TABLE>
Good write up. This is what I had to do when I had to take my MSD ignition out for the CA ref.
Old Jan 10, 2007 | 07:44 PM
Default Re: what kinda MSD is this? and how do i remove it and get back to STOCK? (TurboGS-R)
ok so from what i have read here.... i need to
remove...
ignition box
red box
wiring
and then i need to buy a new..
cap
coil
or basically a whole new stock distributor
if this is right then thanks guys...ill get on it...
thank you all for the answers on this...i dont know if this MSD that i have will cause it to fail smog in the future...but i just want it stock to be safe...
Old Jan 10, 2007 | 07:53 PM
95 integra's Avatar
Thats correct.
Old Jan 10, 2007 | 09:19 PM
thanks bro...
Steeve_Civic
Feb 13, 2013 04:15 PM
PreStaged12s
Aug 23, 2009 08:04 PM
djnikko
Mar 16, 2004 09:46 AM
hmj88hb
Feb 8, 2003 04:50 PM
