Auto P28 ECU in a Manual
Old Jan 9, 2007 | 08:47 PM
92hatch_cx-t's Avatar
Default Auto P28 ECU in a Manual
what would happen if i put an auto p28 ecu in my manual?
Old Jan 9, 2007 | 08:57 PM
gezzuzz's Avatar
Default Re: Auto P28 ECU in a Manual (sohc dis)
http://www.pgmfi.org/twiki/bin...anual
try that..
but i don;t think you can use hondata with it
Old Jan 9, 2007 | 08:58 PM
B18CivicEH2's Avatar
i believe the ecu will have probs with the tranny since its off an automatic and it wants to switch gears itself once it reaches a cetain RPM at certain throttle.. you prob have a CEL but dont think it'll fck sht up....just get the manual p28
Old Jan 9, 2007 | 09:32 PM
Default Re: Auto P28 ECU in a Manual (B18CivicEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEg &raquo;</TD></TR><TR><TD CLASS="quote">i believe the ecu will have probs with the tranny since its off an automatic and it wants to switch gears itself once it reaches a cetain RPM at certain throttle.. you prob have a CEL but dont think it'll fck sht up....just get the manual p28</TD></TR></TABLE>
yeah i know bout the shiftin but do u think it would idle right and rev up fine without drivin it
Old Jan 9, 2007 | 09:47 PM
gezzuzz's Avatar
did you do a manual conversion?
details on why you trying to use a auto ecu one a manual?
Old Jan 9, 2007 | 10:02 PM
slickdowneg's Avatar
Default Re: Auto P28 ECU in a Manual (gezzuzz)
u can buy a $15 chip that will solve the problem from ebay
Old Jan 9, 2007 | 10:04 PM
gezzuzz's Avatar
Default Re: Auto P28 ECU in a Manual (slickdowneg)
post the link slickdowneg(trial)
Old Jan 11, 2007 | 11:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">did you do a manual conversion?
details on why you trying to use a auto ecu one a manual?</TD></TR></TABLE>
no it was already manual. but it wasnt vtec so i had to get a vtec ecu. i had this one layin around
Old Jan 11, 2007 | 11:49 AM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slickdowneg &raquo;</TD></TR><TR><TD CLASS="quote">u can buy a $15 chip that will solve the problem from ebay </TD></TR></TABLE>
learn before you speak
Old Jan 11, 2007 | 12:42 PM
Relic1's Avatar
If you plug in the ECU without converting it to manual you will get a funky idle at times, and a CEL 19 (auto trans solinoid)
Simply convert the ECU to manual trans by doing what this says... http://www.pgmfi.org/twiki/bin...anual
I've done it more times than I can count with zero problems.
The ECU will work with hondata/Crome/Uberdata or any other program like it. (was this even asked??) Once you convert it to a manual trans...
A $15 chip from Ebay will not solve the CEL 19 problem.
Old Jan 11, 2007 | 12:53 PM
dem0nk1d's Avatar
Yeah just do the jumper and resistor mod and your done
OMG WTF
11
May 19, 2016 12:35 PM
hspoon
Aug 22, 2006 07:53 PM
Serdar
Feb 14, 2006 10:52 AM
lazyvietboi
Aug 6, 2004 03:03 PM
