burning clutch?
Old Jan 9, 2007 | 05:50 PM
emoremyz's Avatar
Default burning clutch?
i think my clutcch is burning, but im not sure. when i brake to a complete stop when im sitting there i can smell a burning rubber, when i down shift, while braking i can smell it worse. but when i get out the car it seem like the smell is coming from the back wheel and not the front where everything else is. and the whole time my e- brake is not on at all, well at east no when im driving. Just need to get sum ideas of what it could be.
Old Jan 9, 2007 | 05:56 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: burning clutch? (emoremyz)
If the smell is coming from the back, then it's probably in the back.
Check for any type of rubbing, on the wheel, and in the brake assembly.
Old Jan 9, 2007 | 08:15 PM
95 integra's Avatar
Default Re: burning clutch? (CleanLikeJdm)
Sounds like a locked up rear caliper. The outside pad will look fine but the inside pad will be worn more. Pretty easy to check and see if the slider pins move freely or if they are locked down.
Old Jan 9, 2007 | 09:49 PM
emoremyz's Avatar
ill check those out, appritiate the input, but if my clutch was goin out what would it do?
Old Jan 10, 2007 | 07:14 AM
Hype-R Stalker
It wouldn't be doing things like that.
It would probably slip at mostly high rpms,
Or getting into gears would become very hard.
Old Jan 10, 2007 | 09:13 AM
1337whp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">It wouldn't be doing things like that.
Or getting into gears would become very hard.</TD></TR></TABLE>
agreed if your driving normal it shouldnt burn at all unless your ride/romp it etc.
Old Jan 10, 2007 | 08:44 PM
emoremyz's Avatar
i fixed it, it was a locked up caliper burnig my pads. thanx for the help yall
JRZ88DX
Jan 3, 2008 07:05 PM
jxhxb
25
Dec 7, 2007 07:00 AM
artifact kills
Sep 28, 2006 07:25 PM
d8168055
Jun 21, 2002 10:16 PM
