where this hose go?
Old Jan 9, 2007 | 03:41 PM
smokerz212's Avatar
Default where this hose go?
hey guys i want some help about this hose.. i just notice this hose is no used. if u can point me where this hose goes pls help me tnx. usdm b16a2 converted to obd1 on 92 dx.
this hose
that came from here
Old Jan 9, 2007 | 03:50 PM
smokerz212's Avatar
Default Re: where this hose go? (smokerz212)
pls someone help me bout this.. pls post pic where this one go? or can i just put something to the opening..
Old Jan 9, 2007 | 03:54 PM
Eran's Avatar
HT White Ops
Evap purge solenoid.
Old Jan 9, 2007 | 03:55 PM
smokerz212's Avatar
can u post some pics where i can find this evap pure solenoid?
Old Jan 9, 2007 | 03:59 PM
ef9hatch's Avatar
i think it goes on you firewall somwhere
Old Jan 9, 2007 | 04:04 PM
Eran's Avatar
HT White Ops
Default Re: where this hose go? (ef9hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9hatch &raquo;</TD></TR><TR><TD CLASS="quote">i think it goes on you firewall somwhere</TD></TR></TABLE>
why would a hose go from the inlet of the charcoal canister to the firewall?
koa's Avatar
koa
on mine it goes into the intak mani on the tope left. There is a little nipple it goes onto.
Old Jan 9, 2007 | 04:05 PM
Eran's Avatar
HT White Ops
Default Re: where this hose go? (koa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa &raquo;</TD></TR><TR><TD CLASS="quote">on mine it goes into the intak mani on the tope left. There is a little nipple it goes onto.</TD></TR></TABLE>
as does mine
Old Jan 9, 2007 | 04:17 PM
smokerz212's Avatar
tnx for the pics man. but i i cant find that little nipple on my b16a2.. all i know i dont have hoses running on my IACV and FITV.
Old Jan 9, 2007 | 04:19 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokerz212 &raquo;</TD></TR><TR><TD CLASS="quote">tnx for the pics man. but i i cant find that little nipple on my b16a2.. all i know i dont have hoses running on my IACV and FITV.</TD></TR></TABLE>
Those wouldn't have anything to do with the evap canister.
Old Jan 9, 2007 | 04:29 PM
Eran's Avatar
HT White Ops
Looked into it, and it may go nowhere for your swap. On a 99-00 Civic Si, the evap purge was mounted directly on the canister.
Old Jan 9, 2007 | 04:42 PM
smokerz212's Avatar
ok whats the purpose of this hose? what if im gonna take it out and just cover it? whats gonna happen on my engine?
Old Jan 9, 2007 | 04:52 PM
smokerz212's Avatar
ok can someone give a pic of evap purge solenoid of b16a2 and where is it located?
Old Jan 9, 2007 | 04:53 PM
Eran's Avatar
HT White Ops
It's on the canister, so you'd have to get a canister from an Si. I'm not sure if you used the OBD2B si harness either, because if not, it probably won't even plug in.
On the diagram above, it's the circled part above the canister labeled "17"
Old Jan 9, 2007 | 05:29 PM
smokerz212's Avatar
what do u guys think gonna happen if im just gonna block this hose so that nothings comes out?
Old Jan 9, 2007 | 06:31 PM
qfast817's Avatar
it should be on the fuel rail
Old Jan 10, 2007 | 06:02 PM
smokerz212's Avatar
where is evap purge solenoid of b16a2 located?
Old Jan 10, 2007 | 06:09 PM
smokerz212's Avatar
https://honda-tech.com/zerothread/1858804
Old Jan 10, 2007 | 06:19 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokerz212 &raquo;</TD></TR><TR><TD CLASS="quote">where is evap purge solenoid of b16a2 located?</TD></TR></TABLE>
On the canister itself. As Eran said, as the diagram shows. #17.
Old Jan 10, 2007 | 06:23 PM
Syndacate's Avatar
Default Re: where this hose go? (Syndacate)
It comes down to this. Before the Si the evap purge solenoid was mounted on the top left of the intake manifold. On the Si (The B16a2) the solenoid was moved to on top of the canister, eliminating the hose.
So basically you're using your DX canister which had a nipple that that hose went on to the Si motor which doesn't have the solenoid on it b/c the solenoid is on the canister itself.
So what you do from there I don't know. The only thing I can think of is like Eran said, get the Si canister. Though I have to admit I'm a bit confused, b/c then I think you've been operating w/o any evap purge solenoid...
Old Jan 10, 2007 | 06:34 PM
smokerz212's Avatar
evap purge solenoid is different from evap purge solenoid control valve ryt? if yes. then yes im not using a evap purge solenoid. and if i get a canister from an si that has a evap purge solenoid.. is still dunno where i connect it.
PSI Racing
10
Jan 27, 2020 04:28 PM
floatfisher
Apr 20, 2007 08:32 PM
yan_david
Feb 23, 2007 06:32 AM
Ritchie
Dec 22, 2006 08:12 PM
