where this hose go?
where this hose go?
hey guys i want some help about this hose.. i just notice this hose is no used. if u can point me where this hose goes pls help me tnx. usdm b16a2 converted to obd1 on 92 dx.
this hose
that came from here
this hose
that came from here
Re: where this hose go? (smokerz212)
pls someone help me bout this.. pls post pic where this one go? or can i just put something to the opening..
HT White Ops
Re: where this hose go? (ef9hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9hatch »</TD></TR><TR><TD CLASS="quote">i think it goes on you firewall somwhere</TD></TR></TABLE>
why would a hose go from the inlet of the charcoal canister to the firewall?
HT White Ops
Re: where this hose go? (koa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa »</TD></TR><TR><TD CLASS="quote">on mine it goes into the intak mani on the tope left. There is a little nipple it goes onto.</TD></TR></TABLE>
as does mine
as does mine
tnx for the pics man. but i i cant find that little nipple on my b16a2.. all i know i dont have hoses running on my IACV and FITV.
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokerz212 »</TD></TR><TR><TD CLASS="quote">tnx for the pics man. but i i cant find that little nipple on my b16a2.. all i know i dont have hoses running on my IACV and FITV.</TD></TR></TABLE>
Those wouldn't have anything to do with the evap canister.
ok whats the purpose of this hose? what if im gonna take it out and just cover it? whats gonna happen on my engine?
HT White Ops
It's on the canister, so you'd have to get a canister from an Si. I'm not sure if you used the OBD2B si harness either, because if not, it probably won't even plug in.
On the diagram above, it's the circled part above the canister labeled "17"
what do u guys think gonna happen if im just gonna block this hose so that nothings comes out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokerz212 »</TD></TR><TR><TD CLASS="quote">where is evap purge solenoid of b16a2 located?</TD></TR></TABLE>
On the canister itself. As Eran said, as the diagram shows. #17.
Re: where this hose go? (Syndacate)
It comes down to this. Before the Si the evap purge solenoid was mounted on the top left of the intake manifold. On the Si (The B16a2) the solenoid was moved to on top of the canister, eliminating the hose.
So basically you're using your DX canister which had a nipple that that hose went on to the Si motor which doesn't have the solenoid on it b/c the solenoid is on the canister itself.
So what you do from there I don't know. The only thing I can think of is like Eran said, get the Si canister. Though I have to admit I'm a bit confused, b/c then I think you've been operating w/o any evap purge solenoid...
evap purge solenoid is different from evap purge solenoid control valve ryt? if yes. then yes im not using a evap purge solenoid. and if i get a canister from an si that has a evap purge solenoid.. is still dunno where i connect it.
PSI Racing
10
01-27-2020 04:28 PM
floatfisher
04-20-2007 08:32 PM
