Oil Leak on top of valve cover..HELP
Old Jan 9, 2007 | 03:28 PM
k_lude's Avatar
Default Oil Leak on top of valve cover..HELP
the little bolt that screws the valve cover on top of my valve cover closest to the side of the distrbuter under the spark plug cover always has a little oil on it...is this a major problem..the bolt goes down but it doesnt lock up..it just keeps spinning...is it the bolt or the stud??
Old Jan 9, 2007 | 03:39 PM
nonvteclude's Avatar
Default Re: Oil Leak on top of valve cover..HELP (k_lude)
it could be the bolt or the threads on the inside. pull the bolt if it looks stripped then put a new bolt if not then get a helicoil to fix the threads in the bolt hole
Old Jan 9, 2007 | 03:55 PM
KEVLARsh's Avatar
Default Re: Oil Leak on top of valve cover..HELP (nonvteclude)
mine leaks too, no major problems, it's a very slight leak
Old Jan 9, 2007 | 06:42 PM
Wsteun's Avatar
My block leaks, period. It needs seals lol.
Old Jan 9, 2007 | 06:48 PM
prelude_h22vtec's Avatar
the nuts that go on the valve cover are like $.30. they strip pretty easily if you put more than the 9ft-lbs spec on them
99accordsedanforsale
Classic Hondas
Nov 12, 2007 07:24 AM
doggworld1233
Feb 16, 2006 02:58 PM
SlowB16si
Jan 28, 2006 02:13 PM
SteveB02Si
Dec 7, 2005 09:24 PM
methos713
15
Feb 18, 2005 12:13 AM
