My upper control arm is hitting my suspesion. Help!
Old Jan 9, 2007 | 02:47 PM
EH6TunerDaniel's Avatar
Default My upper control arm is hitting my suspesion. Help!
I have a problem. It seems my upper control arm has decided that it dislikes my strut tower, and has beat a big hole it it. how would you guys go about fixing this?
I also posted this in suspension so maybe I can find out how to prevent it in the future.
Old Jan 9, 2007 | 02:48 PM
turboDeznutz's Avatar
Default Re: My upper control arm is hitting my suspesion. Help! (EH6TunerDaniel)
ouch
Old Jan 9, 2007 | 02:50 PM
Eran's Avatar
HT White Ops
You would go about that by not having your car dumped onto the concrete.
Old Jan 9, 2007 | 03:54 PM
pythoner's Avatar
I have never seen it that bad, that is usally caused by camber kits and being entirly too low
Old Jan 9, 2007 | 04:17 PM
williejohnson's Avatar
New User
you sir have the best aviator hands down
looks like you could just hamer it back down and run a weld where the metal split
i did see somewhere on here where someone welded a little box ontop of the strut
tower for the controle are to go up into
Old Jan 9, 2007 | 04:20 PM
civycoop's Avatar
...dang
Old Jan 9, 2007 | 04:29 PM
00ekcoupe's Avatar
Your car is obviously too low. I had a similar problem except mine wasn't nearly as bad as yours. Simply raise your car. Sooner or later you're gonna have to replace your upper ball joints because they're getting smashed against the strut tower.
Old Jan 9, 2007 | 04:32 PM
pdiggitydogg's Avatar
skunk2 control arms?
Old Jan 9, 2007 | 04:50 PM
Kista20's Avatar
Default Re:
holy shizzle get that expletive thing fixed
Old Jan 9, 2007 | 04:56 PM
Stock control arms, I have an Ingalls camber kit though. Im only dropped on S-Techs too. Looks like I need new springs, and a welder.
Old Jan 9, 2007 | 04:57 PM
Eran's Avatar
HT White Ops
Your shocks could be completely blow too ....
Old Jan 9, 2007 | 05:02 PM
I hope not, AGX's arent cheap, at least not for me, and they are less than 10 months old. Im going to take it to my buddy's tire shop on thursday and see if he can weld it for me. This is strange because I have had this setup for quite some time now and it decided to do it now, it wasnt like that that I can remember just a few weeks ago. Its also only doing it on that one side.
Old Jan 9, 2007 | 05:10 PM
viahiptop's Avatar
Default Re: (EH6TunerDaniel)
take it easy on them dips.
Old Jan 9, 2007 | 05:15 PM
sniggler316's Avatar
Mine did that too, but not as bad. Still not really sure how, because I'm not that low. But yeah, like eveyone said, beat it back down and weld it shut. Be careful, that ish is easy to burn right through!
Old Jan 10, 2007 | 08:40 AM
2coupes's Avatar
get higher springrates, what's you suspension setup? because if you have sleeve coilovers on AGX's they're most likely blown already, that causing the damper not being able to handle the force from a bump and shoving the upper arm into the shock tower
if your shocks aren't blown, you just need to raise the car or get higher springrates, but you can't just get stiffer springs and keep them on AGX's, you'll need to get a full coilover or something that can handle the stiffer rates without bottoming out on the shock tower
Old Jan 10, 2007 | 06:59 PM
Default Re: (2coupes)
Its Tein S-Techs on AGX's. Can I just up the dampening to a harder setting? I have them on 1 right now.
Old Jan 10, 2007 | 07:05 PM
2coupes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH6TunerDaniel &raquo;</TD></TR><TR><TD CLASS="quote">Its Tein S-Techs on AGX's. Can I just up the dampening to a harder setting? I have them on 1 right now.</TD></TR></TABLE>
that will help for sure
Old Jan 10, 2007 | 07:20 PM
Shocka1998LX's Avatar
I have H&R Race Springs (2.5" front, 2.25" rear) on Tokico Illuminas with Omni Power camber kits on all 4 corners and I've NEVER had a problem like this. The illuminas are set on 3 with 5 being the hardest setting possible.
Old Jan 10, 2007 | 07:35 PM
Ok, so Im planning on fixing this tomorrow, Upping my agx's to 4, and saving for a GC/Koni setup. I dont care about ride quality anymore,
I just installed my ASR subframe brace and ITR sway bar too, and because of this I cant enjoy it.
Old Jan 10, 2007 | 07:39 PM
Do you go over speed bumps or dips like an average car does? I take mine like a turtle, and I have to make sure I transfer the weight correctly on the really bad ones.
Old Jan 10, 2007 | 07:42 PM
Pretty much any transition in road elevation I slow down to a crawl for. I think this happened on the highway on unexpected bumps on some bridges. They used to be smooth, but construction came along and fucked them up.
JDM*Teg
May 19, 2008 04:03 AM
nemofoss
Apr 3, 2008 06:01 PM
EH6TunerDaniel
Suspension & Brakes
Jan 10, 2007 01:32 PM
2tone_93gt
Sep 27, 2005 08:23 PM
illusion
Sep 5, 2002 01:23 PM
