help me on a car leak on my 5th gen lude
Old Jan 9, 2007 | 02:45 PM
iJDMBB6's Avatar
Default help me on a car leak on my 5th gen lude
y does coolant keep leaking. like wen i warm up my car in the morning it doesnt leak and wen i start driving it doesnt leak as well .its wen i stop and turn off my the car starts to leak for like 1or 2 min little drop by drops and then it just suddenly stops leaking . recently i changed the coolant hose. can any 1 tell me wats the problem? may the hose be too big dats y it leaks?
Modified by iJDMBB6 at 10:58 PM 1/9/2007
Old Jan 9, 2007 | 03:05 PM
mrmanuke's Avatar
Default Re: help me on a car leak on my 5th gen lude (iJDMBB6)
are you sure it's not just water??
Old Jan 9, 2007 | 03:18 PM
1GPlusSH's Avatar
It took me 4 times reading your question before I totally understood what you were trying to ask.
Have you looked to see where the leak starts? That's where you need to start. Nobody here can tell you your problem with what you've asked. Since you did recently replace a hose, I'd start with where you've tightened the hose. Look there first, and go from there.
Old Jan 9, 2007 | 04:00 PM
KEVLARsh's Avatar
Default Re: help me on a car leak on my 5th gen lude (1GPlusSH)
it might water, you need to find exactly where it's leaking from, let us know
Old Jan 9, 2007 | 09:40 PM
ethereal2pt2's Avatar
Default Re: help me on a car leak on my 5th gen lude (DK-Kip)
you need to work on some basic grammar first. im with you, 1gplussh, had to reread this before i could understand any bit of it.
Old Jan 9, 2007 | 09:43 PM
roller3804's Avatar
that water might be the A/C?
Old Jan 9, 2007 | 09:57 PM
iJDMBB6's Avatar
Default Re: help me on a car leak on my 5th gen lude (mrmanuke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmanuke &raquo;</TD></TR><TR><TD CLASS="quote">are you sure it's not just water??</TD></TR></TABLE>
nah i dont dink so it was the color of the coolant i put in pinkish oil
Old Jan 9, 2007 | 09:59 PM
iJDMBB6's Avatar
yea ill check it out tomorow sry for the bad grammar i was ina hurry
Old Jan 9, 2007 | 10:16 PM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iJDMBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
nah i dont dink so it was the color of the coolant i put in pinkish oil</TD></TR></TABLE>
What does this say/mean???
Old Jan 10, 2007 | 03:22 AM
1GPlusSH's Avatar
It was the color of the coolant that you put in pinkish oil? That makes absolutely no sense unless you put the coolant in pinkish oil.
What color is the coolant that you put in your car? If it's pink, I haven't seen it before. The closest thing I can think of that is pink is ATF. Do you happen to have an automatic or an SH model? If not, I guess that rules out ATF.
Did you ever look to see where the leak starts? Wipe down everything, and let us know. This is definitely my last reply.
Old Jan 10, 2007 | 07:23 AM
DfwBB6's Avatar
im lost here pinkish fluid
Old Jan 10, 2007 | 07:34 AM
Lewdin' Incognito's Avatar
Default Re: help me on a car leak on my 5th gen lude (DfwBB6)
Most likely you've got a small hole or a slightly loose clamp somewhere, so it only leaks when it's hot/pressurized. When you drive for a while, leave the car running and see if you can locate where it is coming from (don't touch the moving thingies ).
For the sake of all that is holy and good; could you please at least type in complete words, maybe a few complete sentences every now and again?
Old Jan 10, 2007 | 08:24 PM
iJDMBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">
What does this say/mean???</TD></TR></TABLE>
i drive an auto and yea i dink my coolant was mixed in with a pink one. i also found the leak. it is coming from the coolant house(located under the car near the oil filter). it is leaking from the top end and bottom end im probably going to bring it to a mechanic to tighten it
Import_spoon
Feb 2, 2007 04:30 PM
JSpekBB4
Jan 23, 2007 09:09 PM
Ri'can Luder
Dec 2, 2006 09:12 PM
96_GSR
Feb 20, 2004 10:38 AM
Blue teg
Dec 17, 2001 07:21 PM
