bouncing idle will not go away!
Old Jan 9, 2007 | 01:50 PM
ED9man's Avatar
Default bouncing idle will not go away!
I just replaced my IACV with a brand new one, no vaccuum leaks to my knowledge. This is a B16a in a CRX. Could the idle screw have something to do with it? I noticed a couple weeks ago all the sudden my CEL came on and the car was throwing 5 codes. I checked under the hood and that screw was totally missing, so I replaced it with a new one and threadlocked it, and everything seemed fine except the same shitty idle. Could the adjustment of that screw be the culprit? What happens is the car will idle stable, but too high and then start bouncing. I don't know what else to check. Thanks.
Old Jan 9, 2007 | 05:34 PM
boostedblkef's Avatar
Default Re: bouncing idle will not go away! (ED9man)
try to check for vacume leaks carefully spray starting fluid around and if it bogs down you got a leak
Old Jan 9, 2007 | 08:35 PM
4DRmafia's Avatar
it could be ur idle is too high and cause it to do that or ur map sensor not reading right, make sure ur map sensoer have a good vaccume and press all the way in
Old Jan 9, 2007 | 10:43 PM
3000GTeg's Avatar
Make sure the screw is adjusted, and definately check your PCV valve, good luck.
Old Jan 9, 2007 | 11:58 PM
4DRmafia's Avatar
^^^ that too
Old Jan 10, 2007 | 04:44 AM
Ovrbst_T66's Avatar
Check the fast idle valve,its located under the throttle body mounted to the im with 3 10mm bolts.There is a link on here that explains on how to fix them i will look it up for you.
Old Jan 10, 2007 | 04:49 AM
Ovrbst_T66's Avatar
Default Re: bouncing idle will not go away! (danny_t66)
Here is the link.https://honda-tech.com/zerothread?id=699787
Old Jan 10, 2007 | 06:13 AM
ED9man's Avatar
Thanks for the tips. My ITR manifold eliminated the FITV. Is there any problem with that, like is the stock computer designed to work with the FITV even though it's not electrical? Also how do I adjust the screw correctly?
Old Jan 10, 2007 | 05:54 PM
ED9man's Avatar
anyone?
Old Jan 10, 2007 | 07:13 PM
4DRmafia's Avatar
that ftiv is only for cold start up.
sc440
Jul 27, 2010 08:22 PM
whitediamond642
Apr 10, 2007 04:37 AM
rice a roni
Apr 15, 2005 09:49 AM
Civic Racer X 7
Jul 23, 2003 07:19 AM
