What engines will fit in my car?
Old Jan 9, 2007 | 12:52 PM
Meatwad1355's Avatar
Default What engines will fit in my car?
I have a 91 civic 4 door sedan, and i am having engine problems with it, it was sugjested to me that swapping the engine would be cheaper than fixing mine,
If i do get it swapped out, since im already having the engine swapped, why not put a better/faster one in.
I looked around and saw alot of different engines i can put in my car, but..
Which engine will swap the easiest/cheapest?
(faster engine, minimap work to swap)
Thanks for your help.
~Ryan
Old Jan 9, 2007 | 12:55 PM
Tippyman's Avatar
Default Re: What engines will fit in my car? (Meatwad1355)
I would start off by searching.
/rant.
But you should probably go with a D-series engine. They'll bolt right in, and you can utulize your stock tranny/axles/shiftlinage/ everything.
If your engine is DPFI now, you have to do an MPFI swap if you are putting in an MPFI engine.
HBK's Avatar
HBK
Since I'm guessing its an LX or Dx sedan, you have a D15b2 with DPFI fuel injection. My recomendations would be to do an MPFI swap and find a clean D16a6 (CRX and Civic Si) motor. Otherwise you could pick up a D15B Vtec, Dohc ZC, or you could step up to Bseries and switch out mounts, shift linkage, harness, etc etc etc.
Cheapest -> D16a6
Old Jan 9, 2007 | 12:59 PM
DaX's Avatar
DaX
Loved
Community Favorite
I dropped a valve in my 90 Sedan a few years back...I searched around on here and a few local forms and found another D15B2 (stock engine) for $20.
If you want to swap in a B-series, the price goes up significantly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">If your engine is DPFI now, you have to do an MPFI swap if you are putting in an MPFI engine.</TD></TR></TABLE>
...or you could retain your DPI manifold and put it on the new D-series engine you get.
Old Jan 9, 2007 | 01:16 PM
Default Re: What engines will fit in my car? (HBK)
Srry, Its a LX Sedan 1.5L D15 i think b2, not sure tho.
If i got the same engine, would it be hard to swap it out myself?
I read around the engine Swapping FAQ's something about renting a hoist and buying your own tools, saving you some money.
and if its the same engine wouldnt it just bolt back in like the other one pretty simple?, connect the same wires/tubes and good to go?
DPFI? MPFI?
Thanx again for the help.
Old Jan 9, 2007 | 01:34 PM
ExemptedNut's Avatar
if its the exact same engine, yes...just swa it out wire for wire bolt for bolt
Old Jan 9, 2007 | 02:02 PM
HBK's Avatar
HBK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meatwad1355 &raquo;</TD></TR><TR><TD CLASS="quote">Srry, Its a LX Sedan 1.5L D15 i think b2, not sure tho.
DPFI? MPFI?
Thanx again for the help.</TD></TR></TABLE>
piece of cake
Saturday I just pulled my motor/tranny out like nothing and put it right back in. Its fun. Just pop open a few beers and let the good times roll.
Old Jan 9, 2007 | 02:27 PM
ilikejesus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote">Just pop open a few beers and let the good times roll.</TD></TR></TABLE> AMEN TO THAT!
Old Jan 9, 2007 | 03:08 PM
jhota's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meatwad1355 &raquo;</TD></TR><TR><TD CLASS="quote">What engines will fit in my car?</TD></TR></TABLE>
anything physically smaller than the car. it just takes money.
d-series probably would be the way to go, though.
Old Jan 9, 2007 | 03:15 PM
Tippyman's Avatar
Default Re: What engines will fit in my car? (jhota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhota &raquo;</TD></TR><TR><TD CLASS="quote">anything physically smaller than the car. it just takes money.</TD></TR></TABLE>
Come on now, that's not thinking outside the box!
Old Jan 9, 2007 | 03:27 PM
ci_vic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meatwad1355 &raquo;</TD></TR><TR><TD CLASS="quote">DPFI? MPFI? </TD></TR></TABLE>
DPFI = Dual-Point Fuel Injection. The engine only has 2 fuel injectors located in the intake manifold. Great for gas mileage, bad for performance.
MPFI = Muti-Point Fuel Injection. One injector per cylinder.
Old Jan 9, 2007 | 03:33 PM
Tippyman's Avatar
Default Re: What engines will fit in my car? (ci_vic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ci_vic &raquo;</TD></TR><TR><TD CLASS="quote">
MPFI = Muti-Point Fuel Injection. One injector per cylinder. </TD></TR></TABLE>
Actually MPFI is a more efficient design. That's why the HF is MPFI.
Old Jan 9, 2007 | 05:08 PM
HBK's Avatar
HBK
Default Re: What engines will fit in my car? (Tippyman)
Actually MPFI is a more efficient design. That's why the HF is MPFI.</TD></TR></TABLE>
yea definitely. I always got better gas mileage with my mpfi crxs then when they were dpfi.
OP? I still think your best bet is to do a multi point fuel injection swap and a d16a6 swap for a little pep, but if your looking for simplicity then just find another d15 somewhere online.
Old Jan 10, 2007 | 04:40 AM
DaX's Avatar
DaX
Loved
Community Favorite
Just get another D15B2 and swap it wire for wire, bolt for bolt, like said above.
If you've never even done an engine swap before, don't even trouble yourself with converting to MPFI.
I get great gas mileage (over 40 mpg) with my DPI - most of a person's FE comes from the driver and not the car.
Old Jan 12, 2007 | 09:20 AM
Default Re: (DaX)
Ok, Im running into money problems and am just gunna try and replace the engine with the same one, i just need it to run, something bad happend to my engine, and when i took it in they estimate 1,300 -1,900 $ (2 shops) for replacing the engine...
so im shopping around for the same engine i have in my car so i can swap it eazy.
(1.5L d15 b2)
I found this engine.
http://www.hmotorsonline.com/s...30021
it says d15b sohc but its vtec so i dont know if its different or what..
Any idea if it will fit in easy no modification?
Oh and if anyone knows where to get a cheap engine (1.5L d15 b2) plz tell
thanks to all for helping me out
Old Jan 12, 2007 | 09:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
That looks like a VX engine.
Post a 'wanted' ad on H-T for a D15B2 engine...I had tons of hits when I did it. Put the ad in the region closest to you so you can go pick it up. I took my wife's accord one time to get an engine...we just put it in the trunk. It was 300 miles away too, but I have found them as close as 25 miles to my house.
Or you could try a junk yard.
Old Jan 15, 2007 | 04:05 AM
DaX's Avatar
DaX
Loved
Community Favorite
Too bad you're not in Maine. You need to keep your eyes out for threads like THIS.
Old Dec 25, 2011 | 08:40 AM
padino's Avatar
Question what engines will fit in a 97 civic 2 door was thinking about 2Liter VTEC 4 cylinder has anyone had much trouble?
Old Dec 25, 2011 | 08:56 AM
crvtectim's Avatar
4G63
Old Dec 25, 2011 | 09:00 AM
melthemonkey's Avatar
Search man. The info is pretty easy to find. But, to answer: You could plop a k-series in there without much problem. It's still a swap, so you'll have to deal with wiring and mounts but it's not really all that daunting of a task. A K is a bit more work than a B-series, but at this point, if you are going to swap-the K is the way to go imo.
BadFoxDragon
Apr 1, 2019 05:59 AM
90DXFlorida
Sep 1, 2018 09:27 PM
gagedally
Honda Civic (2001 - 2005)
Feb 3, 2013 06:01 PM
Daniel_san
31
Dec 9, 2003 07:12 PM
