Idle issues with my b18c1
Old Jan 9, 2007 | 11:00 AM
Shocka1998LX's Avatar
Default Idle issues with my b18c1
I've had the swap in my EK sedan for a few years and I always thought the idle issue was due to the lightweight Hawker battery (very small) I had put in there... so recently I decided to put a factory sized battery back in, and I put in a full aluminum half size radiator and new hoses. No leaks or anything. So, to my knowledge, I've taken care of any performance problems that I thought I had.
Now, the problem. The idle drops so low sometimes when I have the clutch in that the car will occasionally shut off. The motor is completely stock, aside from basic bolt ons. Intake. 2.25" exhaust with removed cat. OBD-I conversion so no second o2 sensor to worry about with the cat being gone. Walbro 255 fuel pump (used to have a turbo motor). Race radiator. Occasionally the car will throw a CEL but it always goes away after I turn the car off and isn't there when I turn the car back on. Not even for a second.
So I gave you guys the basics of the situation. I didnt personally do the swap myself but I've done all the work on it since the motors been in. ANY ideas? This has been going on for a while now. I would just mess with the idle adjustment screw but I want to see what everyone thinks before I do that.
Old Jan 9, 2007 | 11:09 AM
civycoop's Avatar
i was gonna say adjust ur screw..
cuz my car will idle to like 200 and then sometimes 1100?
Old Jan 9, 2007 | 11:24 AM
Speedra500's Avatar
Default Re: (civycoop)
when does the idle drop low? only after the engine is warm? and where does it normally idle at when its warm? If the idle is always low then it probably needs and idle adjustment, but if the probably is not constant it could be a problem with the IACV
Emer925
Feb 19, 2015 10:12 PM
DJP
Jul 27, 2008 11:01 AM
bricks2k4civic
Honda Civic (2001 - 2005)
May 21, 2006 09:44 AM
JustinL
Apr 16, 2003 07:16 AM
Martaigne
Jun 16, 2002 01:53 PM
