water temp question
Old Jan 9, 2007 | 08:14 AM
preludefien
Guest
Posts: n/a
Default water temp question
what is the ideal water tempreture? i just want to make sure my gauge is ready correct bc i dont know how hot the h22a vtec's get...thanks
Old Jan 9, 2007 | 08:28 AM
roller3804's Avatar
Default Re: water temp question (preludefien)
My autometer gauge stays between 180-195 When driving and when in vtec. When i sit it starts to rise but doesn't go higher than 215 and the fan comes on. I have a civic half radiator though. So temps could vary
Old Jan 9, 2007 | 09:20 AM
preludefien
Guest
Posts: n/a
Default Re: water temp question (roller3804)
damn mines is readind 230 with the full radiator..so does that mean that the gauge is fucked bc i know that the car isnt running hot.
Old Jan 9, 2007 | 09:26 AM
117's Avatar
117
My track car stays fairly steady between 180 and 185, even on very hot track days in Texas. I run a Fluidyne with no fans. The gauge is a Defi D-Gauge.
Old Jan 9, 2007 | 10:18 AM
Hawkze_2.3's Avatar
230 is too hot...fan should keep the car below 215 always.
Old Jan 9, 2007 | 01:22 PM
preludefien
Guest
Posts: n/a
Default Re: water temp question (Hawkze_2.3)
so the gauge is wrong...would it be giving a wrong reading if i have the signal wire teed off with the stock water temp wire..
Old Jan 9, 2007 | 03:58 PM
roller3804's Avatar
To get the most accurate reading use the sender that comes with the gauge. I have an auto meter that came with its own sender. The best place to install the sender I think is in the inlet valve right by the head where the ECT switch is. Just buy a drill and tap set that is the same size as the sender. That way it is totally independent from the stock one and u get an accurate reading. Make sure to ground it really well to. I also highly recommend to get quality gauges. I strongly stand by auto meter. The point of getting a gauge is to get accurate readings to be sure u are not hurting your motor. So spend the extra money to get a good gauge instead of a more expensive part of your motor
feel free to pm me if u have any other questions about install or nething
Old Jan 9, 2007 | 06:35 PM
preludefien
Guest
Posts: n/a
thanks man...i actually got the ones from advance auto...the cost a little less than the auto meter but they were just as much as the autometers..the only reason i didnt go with them were because i wanted the green background..the are named faze i think but they were 45.00 a gauge...so do i need to ground the sender unit..would anyone else suggest drilling a whole for the sender...
Old Jan 9, 2007 | 08:06 PM
roller3804's Avatar
I had a faze oil pressure gauge and it was absolute ****. I hooked everything up and it wouldn't even come on. I really would just take the hit and go with a better gauge. The sender is grounded by bieng in contact with the motor itself.
Old Jan 9, 2007 | 09:05 PM
Hawkze_2.3's Avatar
Crappy gauge = crappy reading.
If you get a Defi gauge it will directly replace the stock temp sender without any drilling and tapping.
Old Jan 9, 2007 | 09:23 PM
roller3804's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
If you get a Defi gauge it will directly replace the stock temp sender without any drilling and tapping. </TD></TR></TABLE>
How the hell does that work?
Old Jan 9, 2007 | 09:27 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roller3804 &raquo;</TD></TR><TR><TD CLASS="quote">
The Defi gauge comes with a sender almost identical to the OEM temp sender. It's already pre-wired into the Defi wiring, so you just unscrew the OEM temp sender, screw in the Defi sender, and plug it in.
Old Jan 9, 2007 | 09:38 PM
roller3804's Avatar
damn, you def get what you pay for with defi
I could have done that with my autometer but I wanted the stock gauge and the aftermarket so I could compare
Old Jan 9, 2007 | 10:43 PM
Hawkze_2.3's Avatar
Default Re: (roller3804)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roller3804 &raquo;</TD></TR><TR><TD CLASS="quote">damn, you def get what you pay for with defi
Seriously. I have 3 BF gauges and every time I opened one of the packages I was amazed at the level of detail and the quality of the accessories they give you to install everything. Defi = teh winn4r
Old Jan 10, 2007 | 09:18 AM
preludefien
Guest
Posts: n/a
Default Re: (Hawkze_2.3)
the BF gauges that you are talking about...were do you get those from...and what color do they light up..
Old Jan 10, 2007 | 10:23 AM
Hawkze_2.3's Avatar
Default Re: (preludefien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">the BF gauges that you are talking about...were do you get those from...and what color do they light up..</TD></TR></TABLE>
Enjoy---&gt;https://honda-tech.com/zerothread?id=1660983
Andrew Sutherland
Jun 29, 2008 08:55 AM
innes887
Jun 13, 2007 11:12 AM
crucial-vtec
Oct 28, 2005 11:42 AM
str8boost
Apr 30, 2005 05:21 PM
jdm_gsr
Dec 18, 2003 03:03 PM
