supertech vs skunk2 pro series retainers
Old Jan 8, 2007 | 09:49 PM
AznBlueBoy's Avatar
Default supertech vs skunk2 pro series retainers
supertech makes skunk2 parts but are the retainers the same?
i am going with skunk2 pro2's and i know there is going to be some clearance issues with the valve guide/seal to retainer clearance which crower makes a retainer that is +.060" higher so theres more clearance there and you need to machine the rockers. Now skunk2 makes the retainers with more clearance from retainer to valve guide/seal but the retainer still sits at stock height. I was jus wondering if the supertech retainers were the same.
Old Jan 8, 2007 | 09:51 PM
98vtec's Avatar
moderator emeritus
Default Re: supertech vs skunk2 pro series retainers (AznBlueBoy)
go with RM GEN1 valvetrain and dont worry about modifying the rockers
Old Jan 8, 2007 | 10:23 PM
AznBlueBoy's Avatar
Default Re: supertech vs skunk2 pro series retainers (B.Rabbit)
you dont need to machine rockers with the skunk2 pro series too.
Old Jan 9, 2007 | 03:08 AM
John.'s Avatar
I heard the skunk2 team doesn't even use their own stuff?
Old Jan 9, 2007 | 06:10 AM
AznBlueBoy's Avatar
Default Re: supertech vs skunk2 pro series retainers (BB1JE)
you should read my post
supertech makes skunk2 parts.
Old Jan 9, 2007 | 08:31 AM
Duck Sauce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy &raquo;</TD></TR><TR><TD CLASS="quote">supertech makes skunk2 parts but are the retainers the same?
i am going with skunk2 pro2's and i know there is going to be some clearance issues with the valve guide/seal to retainer clearance which crower makes a retainer that is +.060" higher so theres more clearance there and you need to machine the rockers. Now skunk2 makes the retainers with more clearance from retainer to valve guide/seal but the retainer still sits at stock height. I was jus wondering if the supertech retainers were the same.</TD></TR></TABLE>
If you are using the Supertech dual valve springs, then you will need to order different valve guides/stem seals from Supertech that work with their dual spring setup. But if you are using the standard single valve spring set, then you can just re-use stock.
Old Jan 9, 2007 | 03:42 PM
scootertribe's Avatar
Default Re: supertech vs skunk2 pro series retainers (Duck Sauce)
Also, I emailed skunk2 reference their (or whoever makes theirs) titanium retainers, and the Rep told me to expect to change them out at 20K. Just for your info bro. Good luck.
Old Jan 9, 2007 | 04:39 PM
AznBlueBoy's Avatar
Default Re: supertech vs skunk2 pro series retainers (scootertribe)
yeah i know you have to change them...most people say about 30k but whatever.
ill be using the ST dual valve springs as well with their retainers.
Old Jun 9, 2007 | 09:49 AM
ej_b16a's Avatar
Would clearance also be a problem with skunk2 stage 1 cams and supertech valve springs/retainers. Or only with the higher lift pro2's
Old Jun 9, 2007 | 10:04 AM
NirVTEC's Avatar
Default Re: supertech vs skunk2 pro series retainers (ej_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej_b16a &raquo;</TD></TR><TR><TD CLASS="quote">Would clearance also be a problem with skunk2 stage 1 cams and supertech valve springs/retainers. Or only with the higher lift pro2's</TD></TR></TABLE>
I run the Stage 1's with a pure OEM valvetrain.....~20k miles and still perfect.
Im a fan of anything SuperTech, but when I do my head again it'll be RM VT for sure.
Old Jun 9, 2007 | 10:38 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duck Sauce &raquo;</TD></TR><TR><TD CLASS="quote">
If you are using the Supertech dual valve springs, then you will need to order different valve guides/stem seals from Supertech that work with their dual spring setup. But if you are using the standard single valve spring set, then you can just re-use stock. </TD></TR></TABLE>
Why is this ?
Old Jun 9, 2007 | 05:34 PM
Rosko's Avatar
Default Re: supertech vs skunk2 pro series retainers (lude98SH)
I think the skunk2 retainer is also offset like the offset crower. It shows on their site that its supposed to be shorter than a stock retainer on the underside, but when I set it next to the stock one it looked like it was the same height. What I THINK they do is make the tapered part where the valve lock goes a little wider, causing the retainer to sit a little higher on the valve stem which is what crowers offset retainer is doing. Skunk just doesn't advertise it that way.
Thats just my opinion though, I didn't get the chance to measure anything before I sent my head out to get ported but I'll have it back this week hopefully. I can take a valve out then and compare all three.
Old Jun 9, 2007 | 08:40 PM
hu's Avatar
hu
With Pro 2's, Skunk2 valves, ti retainers, valvesprings, you have to have the rockers machined
Old Jun 12, 2007 | 11:39 AM
hu's Avatar
hu
Any definite answers?
Old Jun 1, 2008 | 09:26 AM
quiksheit's Avatar
Default Re: (hu)
bump...for this being the first time ive heard this.
can anyone clarify?
santeg1992
May 1, 2016 03:52 PM
jesse209eg
Mar 18, 2013 06:08 AM
RMXmitch
Jan 17, 2008 09:46 AM
jime64871
Jan 13, 2008 12:56 AM
