Want to Buy Want to Trade/Want to Buy
WTB: USDM B18C5 engine swap
Old Jan 8, 2007 | 09:05 PM
sicones's Avatar
Default WTB: USDM B18C5 engine swap
got one
Modified by sicones at 11:19 AM 5/10/2007
Old Jan 9, 2007 | 06:44 AM
sicones's Avatar
Default Re: WTB: USDM B18C5 engine swap (sicones)
bump
Old Jan 9, 2007 | 07:44 AM
sicones's Avatar
Default Re: WTB: USDM B18C5 engine swap (pennies_hatchie)
bump
Modified by sicones at 10:03 AM 1/10/2007
Old Jan 10, 2007 | 09:03 AM
sicones's Avatar
dxfvzxc
Old Jan 10, 2007 | 03:14 PM
sicones's Avatar
fasdf
Old Jan 11, 2007 | 11:11 AM
sicones's Avatar
sgsdf
Old Jan 11, 2007 | 03:09 PM
sicones's Avatar
hjhjlhklklkj
Old Jan 11, 2007 | 05:00 PM
DVC2008's Avatar
I have the swap $5800 plus shipping about $100-200 bucks to your door.
EVERYTHING is included.
all mounts
shiftlinkage
ecu
axels
For any car.
Has both vins intact and a bill of sale along with copy of the title will be included.
Im me. Pictures are availible.
Old Jan 11, 2007 | 05:08 PM
sicones's Avatar
Default Re: WTB: USDM B18C5 engine swap (DVC2006)
pm'ed, 5800 must be a misprint
Old Jan 12, 2007 | 06:00 AM
sicones's Avatar
lkjlkj
Old Jan 12, 2007 | 08:21 AM
Down Shift Motoring's Avatar
I have two jdm itr swaps for sale.... 96 spec and 98 spec pm me for details. cheap!
Old Jan 15, 2007 | 08:42 AM
sicones's Avatar
bump
Old Jan 15, 2007 | 01:53 PM
DVC2008's Avatar
Find one yet?
Old Jan 15, 2007 | 02:14 PM
sicones's Avatar
na, IF I end up getting a JDM spec motor it will probably be from hmotorsonline.com, or someone from NY so I can see what I'm buying
Old Jan 16, 2007 | 05:55 AM
sicones's Avatar
asdfasdf
Old Jan 16, 2007 | 06:26 AM
torontojdm's Avatar
I have 96 97 LSD JDM Type R B18c5 with lsd full swap for 3850.00 plus 450 shipping...please let me know or PM me....
http://www.torontojdm.com
email at info@torontojdm.com
416-2850223
reference #b18c59697
Old Jan 16, 2007 | 11:21 AM
sicones's Avatar
Default Re: WTB: USDM B18C5 engine swap (torontojdm)
it's going in a 00 civic, I want/need at least 98+ spec
Old Jan 16, 2007 | 01:16 PM
torontojdm's Avatar
ok we have that engine too...98+ complete for 4650.00 plus shipping...let me know or IM me
416-2850223
Old Jan 16, 2007 | 02:45 PM
SPOON_BeIgHtEeNsEe's Avatar
IM pennies_hatch or something like that he has an 98 usdm itr swap for 3500 located in MN
Old Jan 16, 2007 | 04:54 PM
Crv-tec's Avatar
Yo,
One of my buddies got a USDM B18C5 swap for sale if you haven't found one yet, located in Columbia, SC; area code:29212, i think i remember everything he's got on it:
2000 USDM B18C5
-Skunk 2 Valves
-Skunk 2 Springs
-Skunk 2 Retainers
-Skunk 2 Cam Gears
-Bronze Valve Guides
-ARP Head Studs
-Toda Timing Belt
-LSD Transmission
-ACT Clutch ( Max Pressure Plate & 4-Puck Disc)
-Clutchmasters Flywheel
-Stock shift linkage & Axles (probably throw in a Skunk 2 short shifter)
-I think he might be still missing his distributor tho (something about him lending it to one of his buddies)
-Around 80,XXX miles on the stock bottom end
I think he's looking for around mid 4k or something for it pm if your interested
Old Jan 23, 2007 | 02:41 AM
ValleySyder's Avatar
Default Re: WTB: USDM B18C5 engine swap (Crv-tec)
i got a obd1 gsr swap get a ECUjumping harness .. or you can get a 00 si engine harness if u want to run OBD2 on it
$1600
Old Feb 12, 2007 | 06:40 PM
kaneda3's Avatar
Default Re: WTB: USDM B18C5 engine swap (ValleySyder)
check pms
Old Feb 12, 2007 | 06:49 PM
kaneda3's Avatar
Default Re: WTB: USDM B18C5 engine swap (kaneda3)
actually, ill just reply here
have the king of n/a 1.8's if you are interested, its still in the car and running.
you can even drive it if you want.
fully built jun long block, con rods, pistons, valves, springs retainers, cams, jun ecu, all sensors and wiring to swap into an ek. cusco lsd, custom built tranny.
let me know if you are interested, where are you located? ostego or queens?
revs to 9400rpms
perfect compression across all 4 cylinders(between 250 and 255) you can call the shop that did the test for me
mike
JDM_YANG
May 23, 2009 12:15 AM
EViLSTAR
Apr 7, 2008 09:44 AM
N1_c55
Northern California (Sales)
28
Apr 20, 2007 12:53 AM
dc4drewH
Feb 16, 2005 01:49 PM
