How to remove paint overspray on rubber window trims?
Old Jan 8, 2007 | 07:38 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default How to remove paint overspray on rubber window trims?
Like the topic says, I have a little overspray on the rear rear window rubber, how do I remove it from the rubber? Searched but all it had was how to remove overspray from surfaces that are already painted. TIA
Old Jan 8, 2007 | 07:55 PM
KYLE.'s Avatar
Default Re: How to remove paint overspray on rubber window trims? (rukawa1one)
freind used nail polish remover, it wasn't alot of over spray tho and wasn't to thick so
Old Jan 8, 2007 | 09:28 PM
skinnyboy's Avatar
if its fresh paint, use some Prepsol (wax and grease remover) your going to need a lot and scrub the rubber with a rag soaked in it, it will soften up and you should be able to eventually rub it off.
If the paint is well and truly baked now, i would use thinners and a rag, but stll, i would mask off the areas around the rubbers to be sure
Old Jan 8, 2007 | 10:00 PM
blaxican05's Avatar
Default Re: (skinnyboy)
first try nail polish remover.... if that doesnt work try straight acetone or brake fluid DONT GET ANY ON YOUR CAR
Old Jan 8, 2007 | 10:48 PM
rukawa1one's Avatar
Default Re: (blaxican05)
thanks for the suggestions, the car was painted on sat if that helps
Old Jan 8, 2007 | 10:50 PM
Reza^'s Avatar
Default Re: (rukawa1one)
use a razor blade and have a rag with a wax or armoral on hand.
or mask it off the proper way and paint it black with a can
Old Jan 9, 2007 | 11:50 AM
tegdude227's Avatar
use 3m remover you can use it on paint trim rubber
Old Jan 9, 2007 | 02:45 PM
rukawa1one's Avatar
Default Re: (tegdude227)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 &raquo;</TD></TR><TR><TD CLASS="quote">use 3m remover you can use it on paint trim rubber </TD></TR></TABLE>
Where can i get this product?
Old Jan 9, 2007 | 02:47 PM
LudeEFv2.4's Avatar
My old title sucked.
Home Depot, Ace, any hardware store or even auto parts store should have it.
djviet2000
Paint and Body
May 16, 2007 10:44 PM
rbanke
Apr 7, 2006 06:53 AM
JDMH22HATCH
Mar 10, 2005 07:35 AM
EK_Stunna
Feb 18, 2004 03:45 PM
hybridb18
May 2, 2003 11:03 PM
