Weld-Bond?
Old Jan 8, 2007 | 06:54 PM
hondaboy4life's Avatar
Default Weld-Bond?
I have a friend that works at a body shop and he says now they use this stuff called weld bond... He says it is really solid and he has never had anyone ever come back and say it broke or anything when he put on a new rear 1/4 with it. Has anyone used it? what do you guys think about it? it seems a little sketch.
heres a link i found:
http://www.tooltopia.com/index...31647
Old Jan 9, 2007 | 06:07 AM
Flashmn's Avatar
Default Re: Weld-Bond? (hondaboy4life)
Well. alot of modern cars are put together with glue. Teroson, Unimix, etc make stuff to glue body panels. Its not welding and you cant compare them.
Old Jan 9, 2007 | 03:57 PM
Default Re: Weld-Bond? (Flashmn)
well because i am looking to replace both of my rear 1/4 panels...
Old Jan 10, 2007 | 03:45 AM
Flashmn's Avatar
I'd go mostly for welding.
Old Jan 10, 2007 | 07:26 AM
i dont have a welder right now
Old Jan 10, 2007 | 07:58 AM
swappedcx's Avatar
We use it in college...although we use 3m's automix (i forget the number right now).
Its some pretty crazy ****. GM approved one of 3m's products, and we use it alot, so its pretty good stuff. One thing that you have to be aware of is that you HAVE to weld the rear of the quarter. You HAVE to weld the area of a panel that can be caught in a accident (can only use on non-structural panels of course) to prevent tear-away. With the 3M Products they include the little warranty with their product, and directions with it to show the area's that must be welded). The stuff has a really high tension strength, but if you catch a corner in a accident with no weld that quarter is comming off.
DESTROYER
Welding / Fabrication
19
Aug 13, 2008 11:45 PM
msinsky14
Paint and Body
Aug 29, 2007 11:50 AM
1slowcrx
Jan 5, 2006 12:00 PM
HamiltonRex
Mar 5, 2004 05:15 PM
Shaka
Oct 30, 2002 06:42 PM
