getting this motor!
so...thinkin about getitn this b20 motor
http://passwordjdm.com/product...tails
just want to know what do i need to make this motor a b20 vtec and how much more money am i looking to spend
(motor is going into a 94 honda civic cx hb)
how fast you guy's think it's going to be in the 1/4 mile?
frankenstein swaps are not for noobs like me.
if you have to ask, and have not the slightest idea how to do it, i don think you should try and slap on a vtec head. because theres a lot more too it than that. i was considering doin an lsvtec build earlier. changed my mind. goin w/ an h22.
heres a good write up i found researchinghttps://honda-tech.com/zerothread/1676914 its dealin w/ the ls b18 bottom. but its the same basic concept.
Modified by projekt EJ8 at 4:54 PM 1/9/2007
har-har
i can tell you havent looked because there are an overload of tutorials
if you arent willing to research then you arent ready to do the project
i would guestimate low 15s with the motor
maybe low 14 with the mix-match
well i know b20s running stock with basic bolt ons on a eg will run 14's...its really up to you. If you know alot about building motors i would go with it but if not i'd start off with a gsr motor...best b-series to start with.
you also have to realize that those motors dont include A LOT of necessary parts. you would be looking at spending a lot more on other things to get that motor in your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H9Omega »</TD></TR><TR><TD CLASS="quote">wow i guess in cali the sea level makes a big difference. in my stock 92 cx hatch, gsr swap, intake and exhaust ran a 13.7 on shitty 15 si's.. with a 2.2 60ft.</TD></TR></TABLE>
it was my first motor i ever built and didnt ever get to track it again after, but im sure it was capable od low 13s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">it was my first motor i ever built and didnt ever get to track it again after, but im sure it was capable od low 13s</TD></TR></TABLE>
what happend to it?
what happend to it?
It's pretty much the same as a b18b, its pretty good in my hatch, they come stock in crv's, crvtecs usually fail, build the block as well as swap the head, this guy I know blows head gaskets all the time with his ls/vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 »</TD></TR><TR><TD CLASS="quote">It's pretty much the same as a b18b, its pretty good in my hatch, they come stock in crv's, crvtecs usually fail, build the block as well as swap the head, this guy I know blows head gaskets all the time with his ls/vtec</TD></TR></TABLE>
he's doing something wrong then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 »</TD></TR><TR><TD CLASS="quote"> this guy I know blows head gaskets all the time with his ls/vtec</TD></TR></TABLE>
something is seriously wrong if he keeps blowing head gaskets, read bam bams tutorial on ls/vtec b20/vtec. its much more complicated that you would imagine, it takes alot of $$ to do a b20/vtec correctly so it can handle the revving power the vtec head is capable of.
craftysince86
Sep 15, 2006 09:17 AM
