Civic Type R Steering Wheel Question???
Old Jan 8, 2007 | 05:58 PM
SFBPI504's Avatar
Default Civic Type R Steering Wheel Question???
I have a momo civic type r steering wheel with the airbag and im getting it installed 2morrow on my 2000 civic si my question is will i still b able to keep my cruise control buttons from my orginal steering wheel and can I mount the cruise control buttons some where on the ctr steering wheel????? Thanks in advance for the help
Old Jan 8, 2007 | 06:00 PM
Eran's Avatar
HT White Ops
Unless you'd like to cut into your momo wheel and fab a bracket up in there .... then no, you can't put them on a CTR wheel.
Old Jan 8, 2007 | 06:03 PM
SFBPI504's Avatar
Default Re: (Eran)
Really so is there any way besides cutting up the steering wheel that ill be able to keep my crusie control?????
Old Jan 8, 2007 | 06:24 PM
Eran's Avatar
HT White Ops
Default Re: (SFBPI504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFBPI504 &raquo;</TD></TR><TR><TD CLASS="quote">Really so is there any way besides cutting up the steering wheel that ill be able to keep my crusie control?????</TD></TR></TABLE>
No?
Old Jan 8, 2007 | 06:32 PM
cherryhatch00's Avatar
Make a switch for it elsewhere.
Old Jan 10, 2007 | 07:58 AM
SFBPI504's Avatar
Default Re: (cherryhatch00)
I have another question when I was installing the steering wheel I pulled off a cover on the back of the steering wheel and it was the plug for the cruise control but the cruise control switch from my oem steering wheel plugs in but is upside down and has no way to stay on. I was wondering if the ctr steering wheel has a crusie control button that came with the steering wheel???
Old Jan 10, 2007 | 08:12 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFBPI504 &raquo;</TD></TR><TR><TD CLASS="quote">I have another question when I was installing the steering wheel I pulled off a cover on the back of the steering wheel and it was the plug for the cruise control but the cruise control switch from my oem steering wheel plugs in but is upside down and has no way to stay on. I was wondering if the ctr steering wheel has a crusie control button that came with the steering wheel???</TD></TR></TABLE>
NO.
Old Jan 11, 2007 | 10:56 PM
Dr. Willy's Avatar
Use some double sided tape and tape the buttons on the side of the wheel? lol
Old Jan 11, 2007 | 11:13 PM
Mitsu's Avatar
Default Re: Civic Type R Steering Wheel Question??? (SFBPI504)
uhhh why do you need cruise control?
Old Jan 11, 2007 | 11:19 PM
Eran's Avatar
HT White Ops
And as for that plug you mentioned, that is because the CTR wheel and the EK4 SiR wheel are the exact same, except for color. The CTR is black, with the H dyed red. The SiR is dark grey. The SiR had the provision for cruise control, and thus had an opening in the wheel. The plug is for that hole, so Honda could use the same mould for the plastic shroud piece of the Type R wheel as they could for all other wheels using the same design.
blindguy
Mar 23, 2008 06:56 PM
turdb0
10
Nov 16, 2006 11:40 AM
4drEf-2
Jun 15, 2006 12:07 AM
b18cEK
Mar 23, 2004 06:48 AM
