b18c5 Build up
Old May 14, 2002 | 02:37 PM
99blkcivicsi's Avatar
Default b18c5 Build up
I have a b18c5 head bare with no valve train what so ever. I want to know what all i will need besides ...valves...valve springs....retainers.....cams.....guiders.....???
Also what setup would you advise me to use if i am trying to get the most hp??
[Modified by 99blkcivicsi, 11:43 PM 5/14/2002]
Old May 14, 2002 | 02:41 PM
done's Avatar
Default Re: b18c5 Build up (99blkcivicsi)
crank
Old May 14, 2002 | 02:43 PM
heh...i mean head only sorry for putting block
Old May 14, 2002 | 02:46 PM
reefer_bob's Avatar
Lost Motion Assys...
Old May 14, 2002 | 02:54 PM
FAST94GSR's Avatar
New User
Default Re: b18c5 Build up (Jordo)
crank
Perfect example of someone not reading a post and giving a reply..Do not answer something if you have no idea what the hell you are talking about..
Old May 14, 2002 | 03:00 PM
Default Re: b18c5 Build up (FAST94GSR)
so can anyone give me some good ideas what to use to make the most hp and also where to take it to port and polish? i know of portflow any others out there?
Old May 14, 2002 | 05:13 PM
Big Phat R's Avatar
Portflow is your best bet for headwork. DPR (Dan Paramour (sp?) Racing) does headwork too - but I'm not sure if he has a shop any more.
For the head - you have not provided any information with respect to what kind of motor you want to build. That's kind of important. i.e. what block are you going to use? Is the car going to be a daily driver? What kind of cams do you intend to use? Is the bottom end going to be stock or modified? what is your budget? what kind of driving do you do?
Old May 14, 2002 | 05:43 PM
Default Re: b18c5 Build up (Phat Bastard)
I want a setup for everyday driving but also want lots of power. I am going to build up the block as well and looking for about 195-205 whp . i dont have the block yet just the head. It will be a long term project here and there type thing for about 2 months or so . so the money thing is not a problem. Also what block do you think i should use when i get it? Also what kind of valve train there is none what so ever. Like i said i want lots of power.
[Modified by 99blkcivicsi, 2:45 AM 5/15/2002]
Old May 14, 2002 | 05:46 PM
AllMotorITR's Avatar
New User
Actually, before you start going off about something you are unaware of, the post originally said he needed info on a B18C5 block and so that is why Jordo replied with "crank". Since then the author of this thread edited his initial post and changed block to head. Thanks.
Old May 14, 2002 | 06:47 PM
rodimus's Avatar
Default Re: b18c5 Build up (1 FAST R)
also, this was RIGHT under Jordo's post:
99blkcivicsi
14 posts [100%]
Houston TX
Re: b18c5 Build up (99blkcivicsi) 3:43 PM 5/14/2002
_______
99 CIVIC SI
Old May 14, 2002 | 06:58 PM
New User
Default Re: b18c5 Build up (EVOL)
Some people are so concerned about making someone look bad, when they don't pay enough attention themselves, and end up looking stupid.
Old May 14, 2002 | 08:13 PM
mafay2's Avatar
New User
I think the cost of buying all those parts separately from the dealer will cost you much more than buying a complete head itself.
May be you can try sell the bare head to someone and then buy a completed B16A head and then send it out for a good P&P job.
Old May 15, 2002 | 01:27 PM
Default Re: b18c5 Build up (mafay2)
but the thing is i want all diffrent parts for the valve train. I want diffrent cams valve springs and retainers valves and the only thing i want the same is the lost motions, rockers. Do you know where i can get rockers and lost motions brand new? The stock b18c5 ones are fine. Thanks
Also about how much do they cost???
[Modified by 99blkcivicsi, 10:28 PM 5/15/2002]
Old May 15, 2002 | 01:39 PM
Ausmith's Avatar
Try GSR rocker arms
Call Mike K..... when he gets back.
[Modified by Ausmith, 10:40 PM 5/15/2002]
Old May 15, 2002 | 01:46 PM
Default Re: b18c5 Build up (Ausmith)
where can i find them at and how much?
Old May 15, 2002 | 01:55 PM
Ausmith's Avatar
Call Mike K. at Naples Acura when he gets back from vacation. Search for posts by Mike K. and you will find his contact info in his sig.
I have no idea how much they cost.
RyanR's Avatar
Haha, just buy a complete head. A brand new set of rockers is about $800. Did you get the cam caps? If not, that head is basically trash.
Edit: Nevermind, make that over $1000 for brand new rocker arms. http://www.acuraautomotiveparts.net/...ER+ARM+%282%29
Check out #5.
[Modified by RyanR, 2:56 PM 5/15/2002]
Old May 15, 2002 | 07:08 PM
Default Re: b18c5 Build up (RyanR)
can i use my stock 99 civic si rockers?
Old May 15, 2002 | 11:21 PM
mafay2's Avatar
New User
Check out #5.
I am just about to say "make sure you have your seat belt on before you call to find out how much the brand new rocker arm is from the dealer, so you won't fell out of your chair!!"
They are very expensive, and unless you can find other parts and the rocker arm used, I would just get a complete head and try to sell you bare head.
Em199civicsi
K Series
Dec 31, 2016 05:42 AM
JL2
10
May 29, 2014 10:21 PM
vtec4deaththo
Apr 9, 2009 05:50 PM
99hondacura
Dec 1, 2006 08:03 AM
AMZ GS-R
Mar 11, 2004 07:35 AM
