H22A Valve Lash Adjustment?
Old Jan 8, 2007 | 11:32 AM
EKHWhat's Avatar
Default H22A Valve Lash Adjustment?
I have a H22A in my civic, and I'm looking for the valve lash specs.
I stick the feeler guage in between the cam lobe and the rocker arm, correct? (first time doing this, can't be too hard, right?)
Just set the opposite cylinder to TDC, check the gap, re-gap (if nessicairy), and then lock it all up (then check again after it's locked).
Old Jan 8, 2007 | 04:52 PM
cheehee's Avatar
Default Re: H22A Valve Lash Adjustment? (EKHWhat)
not on an H22 but shows you step by step. I followed this a couple weeks ago, pretty simple, just time consuming. make sure to re-check the gap after tightening down the lock nut. after doing all cylinders I rechecked everything again and needed to make a couple more tiny adjustments.
http://www.c-speedracing.com/h...t.php
if the motor is still in your ride, prepare for a sore back. good luck!
Old Jan 8, 2007 | 05:02 PM
EKHWhat's Avatar
i found the guide on here. got the exhaust valves done tonight.
cpmike
Mar 31, 2007 08:24 PM
Joel2204
Dec 23, 2005 08:13 PM
flashmang
Jul 6, 2004 09:58 AM
se93
Mar 20, 2002 06:17 PM
