STARTING PROBLEMS
Old Jan 8, 2007 | 10:38 AM
andy_1977's Avatar
Default STARTING PROBLEMS
I HAVE GOT A HONDA CIVIC M REG 1.5 3 DOOR
HAVING PROBLEMS GETTING IT STARTED I HAVE CHANGED THE SPARK PLUGS, DIS CAP AND ROTOR ARM
GETTING A SPARK TO VERY POT STARTER IS TURNING BUT WILL NOT START.
ANYONE GOT ANY IDEAS?????
Old Jan 8, 2007 | 10:55 AM
gezzuzz's Avatar
Default Re: STARTING PROBLEMS (andy_1977)
is it getting gas?
get some starting fuild (its in a spray can)
sprary in your intake and see if it fires..
report back with results
Old Jan 8, 2007 | 10:58 AM
andy_1977's Avatar
Default Re: STARTING PROBLEMS (gezzuzz)
its getting gas,have not tryed the spray
Old Jan 8, 2007 | 10:59 AM
gezzuzz's Avatar
so you are sure the injectors are spraying gas?
Old Jan 8, 2007 | 11:01 AM
gezzuzz's Avatar
double check your wires
Old Jan 8, 2007 | 11:07 AM
andy_1977's Avatar
injectors are spraying,wires are correct
there is a spark
Old Jan 8, 2007 | 11:09 AM
gezzuzz's Avatar
what happen to make it stop working..
give details..
Old Jan 8, 2007 | 11:13 AM
andy_1977's Avatar
it was working fine before i went on holiday been stud for a week and a half.
in the middle of the dis cap there was no contact,i thought that was the problem.
i can't understand why it will not start
Old Jan 8, 2007 | 11:20 AM
gezzuzz's Avatar
if you got spark and fuel it could be timming
Old Jan 8, 2007 | 11:26 AM
andy_1977's Avatar
it could be i will have to get it checked out
thankyou very much for your help
if you think of something else please leave a post
andy
Old Jan 8, 2007 | 11:30 AM
gezzuzz's Avatar
i say try starting fuild..
if that don;t work do a compression check
make sure all sensor are pluged in.. all around the intake manifold..
check all fuses!!!
Old Jan 8, 2007 | 11:35 AM
big-cat's Avatar
can u roll start it? have u tried trying to start it with your TB open a bit.
it might be bad gas depending how long u were gone for.
Old Jan 8, 2007 | 12:06 PM
andy_19777's Avatar
Default Re: (big-cat)
have not tryed roll start,what does tb mean?
Old Jan 8, 2007 | 12:33 PM
big-cat's Avatar
if u dont know how to roll start ask. the TB means "throttle body" basically your gas pedal
Old Jan 8, 2007 | 12:42 PM
andy_19777's Avatar
yeah it was after when i left the post i thought that was what u meant.
u think if i bump start it,it might do the job?
Old Jan 8, 2007 | 01:13 PM
big-cat's Avatar
you could try
Old Jan 8, 2007 | 02:53 PM
Dilly's Avatar
so it cranks over but doesnt start up?
Old Jan 8, 2007 | 05:10 PM
allblkcoup's Avatar
dose the check e light come on and the go off when u turn the key on if not then it could be the igniter in the dis or the coil is shot
Old Jan 9, 2007 | 02:20 PM
andy_1977's Avatar
Default Re: (dillywong)
thats right its will crank over but not start
Old Jan 9, 2007 | 02:22 PM
andy_1977's Avatar
Default Re: (allblkcoup)
yes the light comes on then goes off,i get a spark to every pot
I HAVE GOT A AUTO ELECTRICIAN COMING OUT TOMORROW
FINGERS CROSSED HE WILL FIND THE PROBLEM
I WILL POST THE FAULT LATER
Old Jan 9, 2007 | 02:47 PM
Dilly's Avatar
Default Re: (andy_1977)
have you checked your main relay?
Old Jan 14, 2007 | 09:01 AM
andy_1977's Avatar
WELL THE PROBLEM WAS THE AIR INTAKE VALVE KEEPS ON STICKING,
COST ME £62.00 FOR SOMEONE TO LOOK AT IT RIP OFF
grandtheftlunchbox
Oct 12, 2008 05:51 PM
jdsmooth
Mar 7, 2008 04:59 PM
CWITR
May 3, 2005 04:38 PM
JDMBB2
Jan 22, 2004 09:23 AM
Honda Sport
Jun 4, 2003 05:27 PM
