will a larger TB make a diff on a Stock IM?
Old Jan 8, 2007 | 10:26 AM
porter's Avatar
I'm a Jackass
Default will a larger TB make a diff on a Stock IM?
this is for a turbo application, will a larger TB make a diff on a stock IM?
Old Jan 8, 2007 | 10:41 AM
Hawkze_2.3's Avatar
Default Re: will a larger TB make a diff on a Stock IM? (global)
It will make your throttle response faster, but if the plenum isn't port-matched it probably won't do anything as far as power gains.
Old Jan 8, 2007 | 10:53 AM
91preyludesi's Avatar
whats the best method for port-matching the plenum?? is the idea to get the plenum the same size as the TB or slightly smaller?? im thinking of picking up a TB for my NA application but have been holding off casue i dont know if it will be worth it without portmatching it. seems to me that it wouldnt really be worth having a larger TB if the plenum is alot smaller cause the intake charge would get held up at the plenum.
Old Jan 8, 2007 | 01:42 PM
nonvteclude's Avatar
Default Re: (91preyludesi)
when i did mine i just used a diamond dremel bit from home depot and then finished it up with a 750 stone. i had made the opening the size of the tb and slightly tapered it down. it is tedious but well worth it.
Old Jan 9, 2007 | 08:27 AM
esedulerp5tenin's Avatar
Default Re: (nonvteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">when i did mine i just used a diamond dremel bit from home depot and then finished it up with a 750 stone. i had made the opening the size of the tb and slightly tapered it down. it is tedious but well worth it. </TD></TR></TABLE>
how did you prevent **** from getting into the IM?
just blow it out w/ compressed air??
Old Jan 9, 2007 | 03:27 PM
Default Re: (esedulerp5tenin)
ya i just blew it out and then washed it out with some intake cleaner.
HotboxedTypeR
Jun 27, 2008 01:59 PM
hondalove888
May 20, 2008 08:45 AM
viet_boi_racin
Mar 9, 2007 09:04 PM
Charlie Moua
Oct 30, 2003 07:47 PM
shawn_crx
Oct 3, 2003 11:12 AM
