Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Question about Cold Air Intake
Old Jan 8, 2007 | 08:58 AM
06 Habanero-NaVi's Avatar
Default Question about Cold Air Intake
I have the AEM CAI, and I was wondering, we get a lot of rain here in Florida, first off, where do I get that bypass thing at..I called AEM and they didn't have it..and I've been told that you can use them off of other vehicles..like someone told me
(I work at a car dealership) and we have a Scion XB..and he told me I could take it off that ...would that work?? And also..like when it's been raining, or I wash my car, i'll take off, and when I get to around 5 rpm's ...you can hear the intake like it's sucking in water, and I make sure and let off the gas right away...but is that hurting it everytime I do that?? or does it only hurt it if you continue to press the gas or something..the engine kicks back..and I'll take your responses off the air..thanks..lol
Old Jan 8, 2007 | 09:06 AM
The Answer's Avatar
Okay, bro, I wouldn't recommend taking a bypass valve off another car.... specifications differ and all, unless you know that it'll work and you don't have to rig it. Highly recommend an Injen hydroshield, you can get one online, it's fairly reasonably priced.... just make sure you correspond with injen on the size of your filter because they have different sizes of hydroshields.
Old Jan 8, 2007 | 11:48 AM
SickSpd06Si's Avatar
Default Re: (elklodgeezra)
about the by pass valve. you cannot put a by pass valve on our CAI unless you cut the tube (Dont recommend) Like he said ^^^^^ just get a hydro shield and you should be good. I was down in Florida for a week and it just poured the whole time and I had no problems on freeways and all.
Old Jan 8, 2007 | 12:14 PM
Nohawk's Avatar
You only will have problems with water if you continue to go through deep puddles where water is continuously going up around your filter. AEM intake isn't hard to get water too. Injen is more protected.
Old Jan 8, 2007 | 09:54 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elklodgeezra &raquo;</TD></TR><TR><TD CLASS="quote">Okay, bro, I wouldn't recommend taking a bypass valve off another car.... specifications differ and all</TD></TR></TABLE>
As long as the pipe diameter is the same size, any bypass filter would work. People would be surprised though on how much water is really needed to lock an engine up. Its possible though, don't get me wrong.
Old Jan 8, 2007 | 10:05 PM
honda06si's Avatar
Default Re: Question about Cold Air Intake (06 Habanero-NaVi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06 Habanero-NaVi &raquo;</TD></TR><TR><TD CLASS="quote"> And also..like when it's been raining, or I wash my car, i'll take off, and when I get to around 5 rpm's ...you can hear the intake like it's sucking in water, and I make sure and let off the gas right away...but is that hurting it everytime I do that?? or does it only hurt it if you continue to press the gas or something</TD></TR></TABLE>
a little bit of water will not hurt. the temperatures in the combustion chamber are very high so small amounts of water will just evaporate instantly
Old Jan 8, 2007 | 10:09 PM
Default Re: Question about Cold Air Intake (honda06si)
For what its worth, I actually clean inside of an engine using water. Its an old trick, you have to know what your doing but you are basically steam cleaning your engine.
Old Jan 8, 2007 | 10:15 PM
honda06si's Avatar
Default Re: Question about Cold Air Intake (90blackcrx)
what??? never heard of this
you just let the engine get hot and gerk the plugs out and pour freezing cold water down the hole?
Old Jan 8, 2007 | 10:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda06si &raquo;</TD></TR><TR><TD CLASS="quote">what??? never heard of this
you just let the engine get hot and gerk the plugs out and pour freezing cold water down the hole? </TD></TR></TABLE>
Unhook the brake booster vacuum and let it suck in water. Its an old time trick, my college teacher taught me it back in the day.
Old Jan 8, 2007 | 10:18 PM
honda06si's Avatar
haha. weird.
Old Jan 9, 2007 | 11:55 AM
NAmodified's Avatar
as long as the intake doesnt submerge ur all good
martiw2
Oct 20, 2008 12:15 PM
Rs-xtacy
May 17, 2007 06:29 AM
blitz_teg
Oct 20, 2004 09:28 AM
Superman137
Mar 16, 2004 11:32 AM
spoolinq
Dec 19, 2001 09:19 AM
