94 accord no start question-help!
car has spark, compression, fuel - runs good (when started) for ten seconds, then shuts down. Spark plugs also soaked with fuel-almost like flooded or too much fuel. Sounds like problem with computer?? others said distributer, but I have a spark, it does start....main relay?? any suggestions/help?? Thanks
briano210@yahoo.com
briano210@yahoo.com
A few more ideas:
1. the fuel pressure regulator shot?
2. the electrical part of the ignition switch defective? After starting the car, do not let the key return all the way, but hold it back, just enough that the starter will not grind. If that helps, it's #2.
3. There are two or three sensors INSIDE the distributor housing. If one is bad, it can screw up your ignition, like timing.
Do you have a Haynes manual? It would really help you.
jdm_krish
Jun 19, 2018 07:40 AM
94_civic_dx
Nov 5, 2013 05:05 AM
