Welding B16a intake manifold?????
Old Jan 7, 2007 | 09:39 PM
integrawow's Avatar
Default Welding B16a intake manifold?????
I am planning on doing some welding (TIG) on an OEM Honda intake manifold (B18a1). The reason why isn't that important, but what I need to know is if the bond or strength of the weld will be naturally weak since the aluminum being welded is casted?
A while back, I stumbled upon http://www.theoldone.com, and I saw their d-series supercharger manifold. I noticed, and from what the article specified, that the manifold was a cut and welded Edelbrock manifold. Endyn used the Edelbrock runners/flange and welded it to the supercharger plenum. This is why I think that I just might be able to accomplish my goal. However, I don't know if there is a key difference in the grade of aluminum that Edelbrock uses for their manifolds versus the Honda OEM version, which i'm sure they probably do, that allowed Endyn to easily weld aluminum plating to it. I also don't know the grade of aluminum that Endyn used for their plenum.
Any thoughs on this?
Old Jan 8, 2007 | 06:46 PM
integrawow's Avatar
There are probably some of the best welders in the country that are members of this site. Come on, I need to know this.
Thanks ahead of time.
Old Nov 5, 2007 | 10:07 AM
b20vtech's Avatar
Default Re: (integrawow)
bump this up cause i sure need to know too
Old Nov 5, 2007 | 10:20 AM
VeeL_B20's Avatar
Default Re: (b20vtech)
Bump for you man. Very interesting. Would like to see some info.
Old Nov 5, 2007 | 03:02 PM
Evile140's Avatar
Best thing to do is start welding and see what happens. More than likely it will go together good, if you have problems with the old aluminum cracking next to the weld as it cools heat the part up good with a torch or in the oven. Then weld and then let it cool slowly.
Old Nov 5, 2007 | 04:50 PM
9bells's Avatar
OG Fabricator
Default Re: (Evile140)
It will weld fine. Pre-heat to between 175-300 degrees to make welding easier.
It also helps to cook out some of the grease that comes with intake manifolds.
Clean it with brakleen, then acetone or alum cleaner, then pre-heat.
Old Nov 6, 2007 | 07:05 AM
Top Ramen's Avatar
Default Re: (9bells)
Yes - preheat them in the oven, especially the cast part. I usually go to 400 degrees and let it cook for a while to bake out as much of the crap as I can.
Garrett
Honda S2000
Aug 30, 2009 02:38 PM
akhlaq768
10
May 7, 2007 03:31 PM
StolenTeg
Jan 13, 2007 08:18 AM
