shaking problem when in gear!!!
Old Jan 7, 2007 | 08:34 PM
yz125rider21's Avatar
Default shaking problem when in gear!!!
OK my siter has a 1993 accord lx and when I went to use it one day I notice it shakes really bad in reverse and lil bit in drive...could this possibly be a motor mount???Its dark out and I didnt want to look under it when I was at her house to see if there was a broken motor mount or not but I thought I post here tonight to get some tips to look at on the car if it isnt the motor mounts!....thanks in advance
Old Jan 7, 2007 | 08:42 PM
Homesickelian's Avatar
Default Re: shaking problem when in gear!!! (yz125rider21)
Could be the engine itelself. I know I had the same problem when the spark plug cylinders were filled with oil. Anything that can cause one cylinder to misfire bad could be a culprit so maybe bad spark plugs or spark plug wires.
Does it only do it when you move? and if so is it worsened when you jump the RPMs up fast?
Old Jan 8, 2007 | 12:57 AM
well I would think that mate but it passed smog with flying colors couple days ago so wouldnt that toss engine problems out the door?...cause any car misfires 99.9% its failing smog here in cali!!!
Old Jan 8, 2007 | 01:46 AM
raceACCORDingly's Avatar
sounds liek rear mount. its a PITA to get to.
Old Jan 8, 2007 | 08:38 AM
Default Re: (yz125rider21)
no cause mine did pass. It doesnt create many pollutants if it misfires. **** gets recirculated through the engine pretty well. I know California is tight but not that tight...
Also realize that if its misfiring in one cylinder it might not be that bad.
Old Jan 8, 2007 | 08:22 PM
ok mate I look into that when I see the car tomorrow or the next day
Old Jan 9, 2007 | 06:04 AM
Chaos3252006's Avatar
mounts
Old Jan 9, 2007 | 10:51 AM
Default Re: (Chaos3252006)
yeah, people have said mounts already. But it's better to at least see if it's something else before you go to that. Mounts aren't cheap and aren't usually DIY
Brown328
Apr 4, 2013 10:27 PM
austinkli
23
Feb 7, 2008 12:57 PM
sickntired
Jul 20, 2006 03:31 PM
95AccordGuy
Jul 16, 2004 02:54 AM
tub_sephiroth
Sep 22, 2003 09:01 PM
