Ramhorn Turbo Mani, what turbo are you running?
i was running a t3/t67 -38mm wg. no boost creep issues, with 3inchdp/2.5inch exh. another HT user currently has the setup, but is using a BB t3/t67HO
old build thread
new owner of my old setup.
and here too!
Modified by dturbocivic at 7:54 AM 1/8/2007
old build thread
and here too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">i was running a t3/t67 -38mm wg. no boost creep issues, with 3inchdp/2.5inch exh. another HT user currently has the setup, but is using a BB t3/t67HO</TD></TR></TABLE>
So there was no creep even just off the gate spring @ 11lbs
Im just wondering as im going with an sc61 and i have an sls ram horn and its flanged for a 38 and was wondering if id get away with the 38mm or if ill have to run a 44mm
Check my sig for some pics of the ramhorn and turbo
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Spoolin' ramhorn manifold...problem is, it was on an Integra which has a higher radiator support than my EK.
on me for not researching before putting it on...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Spoolin' ramhorn manifold...problem is, it was on an Integra which has a higher radiator support than my EK.
Dang you cut your radiator support.
what would happen if you would have put some kind of elbow there ? Your setup still looks great though.
</TD></TR></TABLE>Dang you cut your radiator support.
I am using a sc61 with a ramhorn and a 38mm gate 12 psi with no creep and 18 psi with no problems.Car has been down for a while though?
Dont mind the fake valvecover it was ditched for an oem
Modified by siblues at 1:57 AM 1/9/2007
im running a rld manifold that was made 3 or 4 years ago
dont mind that filter ont he first pic. was using it to start up my fresh build motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">im running a rld manifold that was made 3 or 4 years ago
</TD></TR></TABLE>Sorry OT, but did you or do you have a problem w/ the oil return with the turbo sits like that? the return is almost sideway like 90* thanks. I use Full-race ramhorn mani and t3/ 60-1 turbo w/ 40mm wg.
Drunken redneck neighbor with a welder (tm) manifold and IHI RHB5
Fits pretty sweet, too.
Racecars are all good fun and all, but 14 second Subaru Justys make me giggle. Wish it were mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastcoast_ej »</TD></TR><TR><TD CLASS="quote">
Check my sig for some pics of the ramhorn and turbo</TD></TR></TABLE>
yea, i had a 2.5inch exh on the car too, maybe if it was open dp or 3inch i would have more of a chance of geting boost creep.
